Flat frames and Offset (CMOS)
3 replies to this topic
#1 nyx
nyx
  • Loc: Germany
Posted 26 September 2021 - 02:31 AM
Quick question regarding flat frames using, in my case, a monochrome CMOS camera (QHY183M): does offset need to be the same as the lights?
Using NINA's there is no way one can set the offset within the Flat Wizard (except on the Equipment > Camera page). The Flat Wizard allows you to define a gain value but not offset. Does NINA automatically tweak offset behind the scenes (during flat frame histogram/exposure calculation)?
Similar story in SharpCap. If I use my light frame settings (gain, offset, etc.) I get a warning that Too many pixels are below 10% saturation, even if the histogram looks correct (peak at 50%). Only when I increase the offset value (and slightly decreasing exposure to compensate) do I get the Histogram: OK status from SharpCap.
#2 imtl
imtl
  • Loc: Down in a hole
Posted 26 September 2021 - 06:15 AM
Gain, offset, temperature (with darks) should match your lights. Otherwise you won't be able to calibrate properly.
Don't know what camera you are using but you can set the offset probably in the camera driver
  • nyx likes this
#3 nyx
nyx
  • Loc: Germany
Posted 26 September 2021 - 08:08 AM
I went back and checked the filename of the flats I shot with NINA and yes, you are right, NINA shot them with the same offset defined in the Equipment > Camera page. I will ask in the SharpCap forums how to get past this Too many pixels below 10% saturation warning without changing the offset. Thanks!
#4 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 26 September 2021 - 10:06 AM
This is one of the very few issues I have with NINA. If you're providing me with a nice wizard-based way to setup and take flats, and in that process you allow me to set the gain, exposure length, filter, light panel brightness, etc, why, oh why don't you let me set the offset as well? Why do you force me to go to the equipment page and change the camera's default offset there? I mean, you allow me to enter an offset when I'm creating a sequence, so I know the code has been written and implemented elsewhere in the product ;).
  • OldManSky likes this
