DSO Photos May 17 - June 15
7 replies to this topic
#1 Echo
Echo
Posted 17 May 2004 - 04:22 PM
Welcome to the Cloudy Nights Reader’s Gallery Submission Forum. Each month we ask CN members to submit their best DSO photos.
For your photo entries, please provide a description that includes:
your First and Last Name;
Date of photo (can include the time);
Description (title) of the image;
Relevant photo information (exposure length and equipment used).
This is important! If you don't supply ALL information, we won't be able to use your photograph!!!!
Please note: due to copyright issues, all photos should be original (If they aren't then you will be banned from this section of the forum!).
This month's deadline is June 15th, at 1700 hours Greenwich Mean Time.
To facilitate the judging we respectfully ask that you not enter comments in the photo thread. You will find a commentary thread for the DSO entries. Thanks and good luck!
#2 synner
synner
Posted 22 May 2004 - 09:06 AM
OK I'll start off this month :-)
I had a go at NGC7635 the Bubble nebula last night.
I took a combination of normal and Ha exposures to increase the number of stars showing. It was pretty blustery last night, and though I grabbed 62 frames, only 23 were usable. I also waited too long to take the normal exposures, so the sky was getting a bit bright for the SC3 camera and I was only able to get 8 frames.
Taken from Harrow in the UK, 040522 from about midnight (UT) onwards.
The image is a composite of 23 x 120s exposures with an Astronomik 10nm Ha filter, and 8 x 20s normal exposures. Shot with a ToUcam Pro SC3 through a Vixen VC200L and a 0.5x focal reducer, mounted on a Losmandy GM-8. Recorded in K3CCDTools v2, aligned and stacked with Keith's Image Stacker, then adjusted with the Gimp.
Cheers
Nick King
#3 michaeloconnell
michaeloconnell
Posted 31 May 2004 - 05:54 AM
Here's my first proper attempt at deep sky astrophotography.
Any tips anyone?
Michael O'Connell
29-30 May 2004
M57 - Ring Nebula
LX90 @ f/10 in alt-az mode, 18x30sec images, ISO1600, Canon EOS 300d, Photoshop 5
Sky was a bit hazy and a 75% moon didn't help either - that's my excuse anyway ;)
#4 synner
synner
Posted 31 May 2004 - 06:42 AM
M27 the Dumbbell Nebula
Harrow UK, 040530
This image is an LRGB (HaHaGB) composite comprised of 42 x 60s exposures in Ha used as L and R, 30 x 20s exposures in B and 30 x 40s exposures in G. I used an Astronomik 13nm Ha filter, an Orion 58 green filter and an Orion 80a blue filter for these exposures.
Taken unguided with the ToUcam Pro SC3 at prime focus of the Konus 80mm short tube refractor at f5. Recorded in b/w RAW mode in K3CCDTools v2. Alignment and stacking was done with Keith's Image Stacker, image adjustment and colour balance was done with PhotoshopCS.
Cheers
Nick
#5 Guest_**DONOTDELETE**_*
Posted 08 June 2004 - 03:47 PM
M27 from my back garden on Merseyside UK.
70x30s and 3x1min images taken with a 300D set at iso 1600 at prime focus of an Lx90 @ f6.3 in Alt/Az
Aligned and stacked using adaptive add ,digital development and mask processing also used in ImagesPlus.
No Flats or Darks used.
Final cropping, re sizing and levels and curves done with PS8.
Steve Jones
#6 EricCCD
EricCCD
Posted 10 June 2004 - 08:33 AM
This was posted earlier this week in the CCD forum.
My name: Eric Africa
Date of photo: June 5, 2004
Description (title) of the image: LRGB M51
Relevant photo information:
Equipment: SBIG ST-7E with CFW-8a filter wheel shooting through a Takahashi FS-102 on an EM200 Mount.
L: 2 x 10 minutes binned 1x1
R: 2 x 10 minutes binned 2x2
G: 2 x 10 minutes binned 2x2
B: 3 x 10 minutes binned 2x2
This is just my third attempt at LRGB imaging. The shortness of the L data is just so I have an L to work with; I have a 90-minute L image taken earlier this year that I hope to merge with the color information.
Enjoy!
Eric
#7 MarkK
MarkK
Posted 10 June 2004 - 02:51 PM
Omega Centauri
Keys Florida
Mark Keitel
Scope: Tak FSQ 106
Location WSP 2004
Camera: SBIG 10xe
Exposures: RGB 9 x 480sec each filters
Mount: AP1200 ( the TakFSQ is one of three scopes on the mount a TakFRC300; TakFSQ106; TakFS-60c)
Weather was winds 20mph with gusts up to 40mph. Was in a Kendrick tent and could not image that night with the large scope. The wind was so strong that guiding was an issue.
Being that it has been raining and cloudy here lately gave me some time to look over some older images. I found that I had the Red and Blue channels mixed up. ( I know have a different filter wheel that I personally put the filters into and labeled them so this would never happen to me again)
I think that the little miss-hap and the end results are startling
If you want to go galaxy hunting in the image I suggest you view the larger image and find the following
1) PGC 47003 @ 14.0mag
2) PGC 47092 @ 14.1mag
3) PGC 47306 @ 17.0mag, 21arc.mins below PGC 47092 .
4) PGC 47340 @ 14.5mag in the lower left corner of the image.
5) LEDA 159037 @ 16.3mag on the middle left edge of the image.
6) LEDA 159028, no Mag given, 4.8arc.mins left of LEDA 159037 the image.
Large 2.9mb
http://web.tampabay....lorwebLarge.jpg
Thank you
Mark
* If you are one of the lucky ones that can not get to the image by clicking on the link and get a forbidden message you can then click the goto button on your browser after you get that message and it should work or you can simply copy and paste the link into your browser and then hit goto and that should work too
#8 MarkK
MarkK
Posted 11 June 2004 - 06:38 PM
Not sure if I will get the color of this image done soon since it is rainy season here in the Tampa Florida area
Mark Keitel
Tak FRC300 F/5.9
AP 1200 mount
SBIG 10xe camers Custom Scientific 4.5nmHa filter
My backyard
11 x 900 seconds
