Orion Atlas EQ-G Pre 2009 mount
7 replies to this topic
#1 ki6bu
ki6bu
  • Loc: Mesa, AZ
Posted 28 September 2021 - 01:24 AM
I am getting back into this hobby after 12 years.  I have an Orion Atlas EQ-G Pre 2009 mount.
I would like to change out the saddle from the original (which just loves to mar up the dovetail bars)
to a dual, like the newer EQ-G/ EQ6 mount has.  The problem is the newer style from Orion does not fit and they
no longer make the original replacement.  I was even looking for a replacement puck but no one gives dimensions
so I can't tell if they fit.  The old one measures 2.9" outside diameter.   Does anyone have a solution for this?
Henry
Edited by ki6bu, 28 September 2021 - 01:25 AM.
#2 TheSheriff
TheSheriff
  • Loc: Duck Football Country
Posted 28 September 2021 - 02:00 AM
This might be it, not sure.  You would need to check the profile.  It's been awhile and I can't remember which is which (Old vs new).
https://www.admacces...n-atlas-mounts/
When I did that on my older Atlas, I just went this route...
https://www.amazon.c...r/dp/B003CPNAXO
For me it was cheaper, and the bonus of a more secure/rigid connection.  I took it a step further and drilled two holes in the puck to bolt (from underneath) the vixen portion of the adapter to the puck.  I could then remove those two hand screws that are marring your dovetails.
  • jdupton likes this
#3 macdonjh
macdonjh
Posted 28 September 2021 - 07:49 AM
+1 for ADM.
#4 Pauls72
Pauls72
  • Loc: LaPorte, IN USA
Posted 28 September 2021 - 10:45 AM
I have replaced the original saddle on both my Atlas mounts with ADM's, they are expensive, but great.
The difference between the old and new style is the mounting disc.
  • Applal likes this
#5 ki6bu
ki6bu
  • Loc: Mesa, AZ
Posted 28 September 2021 - 08:05 PM
Thanks guys,
Last year I ordered from Orion the new dual saddle which claims to work with the EQ-G.
The profile was correct but the diameter was smaller so I returned it and after a phone conversation, found out
that the part is no longer available.  So at this point I believe the current pucks are smaller in diameter.
It's very frustrating that there is a lack of dimensions given on many "metal items" in this hobby.
I called ADM but just got the answering machine.  I'll try again tomorrow.
#6 Mert
Mert
  • Loc: Spain, Pamplona
Posted 29 September 2021 - 09:37 AM
Have a look at Teleskop service, I bought the Geoptik adapter and saddle. The have 2 versions
Edited by Mert, 29 September 2021 - 09:37 AM.
#7 Applal
Applal
  • Loc: Larsen, WI
Posted 29 September 2021 - 10:24 AM
I did my 2008 EQ-G Atlas with the ADM puck and dual dovetail. It worked perfectly and the quality lasted (and it still just fine!)
#8 ki6bu
ki6bu
  • Loc: Mesa, AZ
Posted 30 September 2021 - 08:52 PM
I ordered the puck and dual saddle.  Thank you guys for confirming the fit.
Henry
  • TheSheriff likes this
