Data to play with! Jupiter, Great Red Spot transit, moons, animation best seeing 2021-10-07
79 replies to this topic
#1 Ittaku
Ittaku
  • Loc: Melbourne, Australia
Posted 09 October 2021 - 01:05 AM
This was the best seeing night I can recall this year 8.5/10 so I captured a lot and really didn't know when to stop processing to do all the captures justice.
See here for my Saturn and Neptune images from the same night:
https://www.cloudyni...ing-2021-10-07/
Hardware: Celestron Deluxe CPC 1100 Edge HD, Optolong UV/IR block, Siebert Barlow, ZWO ASI 485MC.
Software: Firecapture, PIPP, Winjupos, Autostakkert, Astraimage, The Gimp, apngasm, ffmpeg
I don't recall seeing blue streaks so clearly within the Great Red Spot with any of my captures. The bright white breakouts have turned into regular swirls without the intense brightness. The sharp edge to the swirls above the GRS have smoothed off and become round again.
Jupiter 150%
Europa, Jupiter, Io, and Ganymede (click for imgur 4k version)
Lowres animated gif (click for full resolution bouncing PNG)
Crossed eye stereogram
Relaxed eye stereogram
And just for fun
Screenshot 20211009 141517
Screenshot 20211009 141454
Here is a link to the 3 minutes of GRS transit in case you wish to check out your post-processing skills, I'd love to see what people can do with it!:
https://drive.google...iew?usp=sharing
Note it was captured in alt/az so you could play with both field and planetary derotation in winjupos.
Diameter=45.43"
Magnitude=-2.67
Altitude=66.82°
CMI=211.4° CMII=9.6° CMIII=206.0°  (during mid of capture)
FocalLength=4200mm (F/15)
Resolution=0.14"
Thanks for viewing, and enjoy!
Edited by Ittaku, 10 October 2021 - 12:05 AM.
  • Sunspot, PrestonE, JMP and 30 others like this
#2 Tulloch
Tulloch
Posted 09 October 2021 - 01:43 AM
Great images, outrageous AS!3 quality graph!
  • dswtan, Scott Mitchell, dcaponeii and 1 other like this
#3 clusterbuster
clusterbuster
  • Loc: Tampa Bay, Fl.
Posted 09 October 2021 - 02:05 AM
very nice !
Mark
  • Ittaku likes this
#4 BQ Octantis
BQ Octantis
  • Loc: Mid-Atlantic, USA
Posted 09 October 2021 - 06:15 AM
  • Ittaku likes this
#5 JMP
JMP
Posted 09 October 2021 - 02:20 PM
Full size animation is impressive!!!
  • Ittaku likes this
#6 Kiwi Paul
Kiwi Paul
  • Loc: Carterton, New Zealand
Posted 09 October 2021 - 02:41 PM
Wow! Are you ever doing good work these days! These image are excellent. I see there is still a convective cold top 10 o’clock of the GRS along with a dark (downdraft?) area. I find the relaxed eye stereogram the easiest for me. It looks great. Maybe it bulges a tad too much (which is related to the interval between pics as you will know).
Cheers Paul
  • Ittaku likes this
#7 Borodog
Borodog
Posted 09 October 2021 - 03:26 PM
Fandamtastic.
  • Tim J Fowler and Ittaku like this
#8 Ittaku
Ittaku
Posted 09 October 2021 - 03:51 PM
Thanks! I was thinking of hosting those best 3 minutes somewhere for people to play with, curious to see how people process it differently.
very nice !
Mark
Thank you.
Thanks! Unlike most of my previous animations, the seeing didn't even change much over the entire 2 hour pass.
Cheers Paul
Thanks, but the seeing should take the credit for these, though it's good to have put to rest all my optical issues and finally have a camera that suits my workflow almost ideally. For these stereograms I put 10 minutes between the two images instead of making the centre of the stacks 10 minutes apart, so it seems you're paying very close attention.
Fandamtastic.
Thank you sir.
  • Kiwi Paul likes this
#9 Kiwi Paul
Kiwi Paul
Posted 09 October 2021 - 05:45 PM
Yes that would be great if you put that data somewhere. I haven’t been imaging last couple of months due to recovering from a big back operation so I would love to play with them.
Paul
  • Ittaku likes this
#10 Ittaku
Ittaku
Posted 09 October 2021 - 06:37 PM
Okay, here's a download link to the 3 minutes of the great red spot transit. I'll put a link in the top post as well whilst I can still edit it. Feel free to post your images here, and go nuts!
Note it was captured in alt/az so you could play with both field and planetary derotation in winjupos (as I did with video derotation.)
Diameter=45.43"
Magnitude=-2.67
Altitude=66.82°
Resolution=0.14"
Edited by Ittaku, 09 October 2021 - 07:11 PM.
#11 Kiwi Paul
Kiwi Paul
Posted 09 October 2021 - 07:11 PM
Thanks. I’ll have play.
Paul
  • Ittaku likes this
#12 tboss70
tboss70
  • Loc: Missouri
Posted 09 October 2021 - 07:51 PM
wow, I've never had seeing like that. I'll to play with the images when I get time. Nice work.
  • RedLionNJ and Ittaku like this
#13 Ittaku
Ittaku
Posted 09 October 2021 - 08:32 PM
By the way, the capture was at my regular medium rate of 30fps so it's not that much data by comparison and won't take that long to stack.
#14 Tulloch
Tulloch
Posted 09 October 2021 - 09:15 PM
Thanks Con, this is what I would do with that data using my (current) techniques smile.gif. The colour balance is still slightly different from where I would like to be, but it's close enough for me. I like the little detail in the GRS that you captured.
Thanks for sharing...
2021-10-07-1104_4-2021-10-07-1102_0-CK-L-Jup_pipp_AS_P50_lapl6_ap99_Driz30 Jup925Kiwi r095g1b105 ps3sm100.png
[EDIT]: Updated the image to reduce some of the red, happier with this version.
Edited by Tulloch, 10 October 2021 - 04:50 PM.
  • PrestonE, dswtan, Mirzam and 6 others like this
#15 Ittaku
Ittaku
Posted 09 October 2021 - 09:37 PM
Thanks very much for that, looks great and as expected it has the same personality as your regular images. I actually resisted adjusting colour balance at all this time. I didn't even boost saturation which I'm normally tempted to do. I used the colours straight from the camera as is.
#16 Tulloch
Tulloch
Posted 09 October 2021 - 09:47 PM
Heh, we all create our images in our own likeness :)
I always find these images need a bit of a colour boost - this one is a little higher in the red than I would normally like but when I tried adjusting the red channel it turned out too blue :). Maybe there's something in the green channel also...
  • Ittaku likes this
#17 Ittaku
Ittaku
Posted 09 October 2021 - 09:51 PM
I always find these images need a bit of a colour boost - this one is a little higher in the red than I would normally like but when I tried adjusting the red channel it turned out too blue smile.gif. Maybe there's something in the green channel also...
Yep there's absolutely no doubt in my mind after playing with 6 different OSC cameras that each creates a different colour balance, and so does the choice of IR filter. I've been intentionally chasing more blue information from both the 485 camera and Optolong filter, and I'm wondering if that explains this extra blue detail in the GRS, even if the gain settings didn't end up being where I expected with the camera.
#18 troyt
troyt
  • Loc: Hunter Valley, Australia
Posted 09 October 2021 - 11:13 PM
Good images,
The colour balance looks pretty good straight off the camera just wondering the Wred and Wblue values at capture.
Basic work flow.
> Registax- wavelts, colour balance
> Photoshop - saturation, noise reduction, contrast
Troy
  • PrestonE, Ittaku and HarveyDeckAstro like this
#19 Ittaku
Ittaku
Posted 09 October 2021 - 11:16 PM
Good images,
Basic work flow.
Thanks Troy. Looks great. Wred 63, Wblue 91 (hardware in top post.)
  • troyt likes this
#20 R Botero
R Botero
  • Loc: Kent, England
Posted 10 October 2021 - 07:11 AM
Roberto
  • Ittaku likes this
#21 tboss70
tboss70
  • Loc: Missouri
Posted 10 October 2021 - 08:59 AM
Here is my attempt and thanks for posting this great data to experiment with.
  • JMP, Kenny V., Kiwi Paul and 2 others like this
#22 HarveyDeckAstro
HarveyDeckAstro
  • Loc: Short Hills, New Jersey
Posted 10 October 2021 - 09:12 AM
Thanks for this amazing data! I watched the video and the details in individual frames are quite vivid. Now I get to know what it means to have a great seeing and accurate focus. A invaluable reference point for improving my processing skills!
#23 HarveyDeckAstro
HarveyDeckAstro
Posted 10 October 2021 - 09:17 AM
Really lovely processing! What does the processing flow looks like?
  • tboss70 likes this
#24 Borodog
Borodog
Posted 10 October 2021 - 10:24 AM
Astounding data.
  • Kenny V., R Botero, Kiwi Paul and 2 others like this
#25 tboss70
tboss70
  • Loc: Missouri
Posted 10 October 2021 - 10:30 AM
There are others I am sure who can do better than I can. I try to keep it simple and with data like this it sure does make it easier, although, Im sure there's much more that could be done.
Here is all I did, then just a touch up in Gimp with Saturation and Sharpening. I start with trying to see what will give me my sharpest/finest detail.
If you run it through AstroImage I use Simple Deconvolution and adjust the blue kernel size.. Then Micro Contrast. I think Registax might do a little better job here.
  • Kiwi Paul, Ittaku and HarveyDeckAstro like this
