Messier 51 M51 NGC 5194, Canes Venatici (Whirlpool Galaxy)
Astrophotography CCD CMOS DSLR DSO Filters Imaging Orion Refractor
11 replies to this topic
#1 rekokich
rekokich
  • Loc: Virginia
Posted 11 October 2021 - 02:30 PM
Image details:
-TSapo100q astrograph, Sigma APO 1.4x tele-extender, 100 x 812mm
-Modified Canon T3i camera, Astronomik CLS-CCD filter
- Celestron AVX mount, Orion 60mm F4 SSAG pro autoguider
-7 x 240 sec subexposures, iso 1600, 30 darks, 30 bias, 2x drizzle, 50% area crop, processed as RGG
-Software PHD2, DSS, XnView, StarNet++, StarTools v 1.3 and 1.7
Total integration time is only 28 minutes. I had been planning to get around 2 hours, but I lost an argument with clouds. Still, the image came out better than I expected.
M51 NGC5194 (GG) CVen E2LGS 1140 TS (1.4x) 100-812 7x240''-1600-m-cls-37F.jpg
  • Ptarmigan, jim kuhns, mikewayne3 and 15 others like this
#2 rekokich
rekokich
  • Loc: Virginia
Posted 11 October 2021 - 02:32 PM
M51A (NGC5194) was discovered by Messier on October 13, 1773 while cataloguing nebulous objects which might be mistaken for comets. The small companion galaxy, M51B (NGC 5195) was first documented by Mechain in 1781. In 1845 this nebula was the first in which Earl of Rosse recorded a spiral structure with his large 72 inch reflector in Ireland. The meaning of spiral nebulae remained unclear until Edwin Hubble identified them as separate galaxies through distance measurements using Cepheid variables. More recently, radio telescopes defined M51 as a Seyfert galaxy, emitting strong radio signals from its bright, active core. In 1992 and 2005 high resolution Hubble images revealed two nearly perpendicular dust rings most likely orbiting a massive black hole in the galactic center. The attached photograph clearly shows spiral arm deformation along the E and N quadrants of M51A caused by gravitational interaction during a close passage of the smaller galaxy M51B about 550 million years ago. The smaller component appears to be gravitationally captured by the larger galaxy, and the two will eventually merge over hundreds of millions of years.
The larger component of M51 has an angular diameter of 11.2 arcmin and apparent magnitude of 8.4 - visible in binoculars under good sky conditions. The distance is estimated at 22 million LY, the diameter at 70 thousand LY, and the mass at 160 billion solar - about one third the mass of the Milky Way.
In addition to the main target, the image contains small galaxies IC 4278, NGC 5198, IC 4263, NGC 5169, PGC 91291, and PGC 2299047. SIMBAD and NED databases indicate that the field is also strewn with numerous quasars, all of which are fainter than the limiting magnitude of 18, and therefore failed to record.
M51 NGC5194 (GG) CVen E1LGSAC 1140 TS (1.4x) 100-812 7x240''-1600-m-cls-37F.jpg
  • Ptarmigan, Mert, Quaternion and 5 others like this
#3 fallenstarseven
fallenstarseven
  • Loc: San Mateo, CA, USA
Posted 11 October 2021 - 02:41 PM
A really beautiful and intriguing image, and I love the detailed second image with all the information about the objects, well done.
I'm becoming fascinated with M51 and NGC5195.
#4 pixlimit
pixlimit
  • Loc: Hamburg, Red Zone
Posted 12 October 2021 - 06:28 AM
nice widefield of M 51 and friends
#5 rekokich
rekokich
  • Loc: Virginia
Posted 14 October 2021 - 01:17 PM
Thank you fallenstarseven and pixlimit for encouraging comments.
#6 Mert
Mert
  • Loc: Spain, Pamplona
Posted 15 October 2021 - 06:53 AM
Very nice wide field and interesting information.
I like the presentation!
#7 rekokich
rekokich
  • Loc: Virginia
Posted 16 October 2021 - 03:07 PM
Thank you, Mert.
#8 Professor2112
Professor2112
  • Loc: Massachusetts
Posted 16 October 2021 - 08:58 PM
Wow! This is amazing for only 28 mins!  I always thought this was too small a target to do justice with my equipment, but it seems I was wrong there. I’ll definitely be trying this once I can get some dark sky time.  I can’t believe the amount of dust you captured extending off NGC 5195 in such a short time.  Bravo!
#9 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 17 October 2021 - 03:52 PM
One of my favorite objects! Love your wide-field. Here is my take from last May taken at the native fl of my Edge 11HD.
Michael
  • rekokich, j.gardavsky and jokrausdu like this
#10 rekokich
rekokich
  • Loc: Virginia
Posted 18 October 2021 - 12:47 PM
Thank you, Andrew. Yes, the skies were excellent until they suddenly weren't.
#11 rekokich
rekokich
  • Loc: Virginia
Posted 18 October 2021 - 02:43 PM
Thank you, Michael. Here is what I got playing with your very low res image above. It must be very rewarding to work at this scale! I would like to see more of your images.
Rudy
#12 MHamburg
MHamburg
Posted 19 October 2021 - 10:35 AM
Here are a couple that came out well.
Saturn
M27
M57
Michael
  • rekokich likes this
Also tagged with one or more of these keywords: Astrophotography, CCD, CMOS, DSLR, DSO, Filters, Imaging, Orion, Refractor
