What's causing those horizontal lines?
13 replies to this topic
#1 mannys
mannys
  • Loc: San Francisco Bay Area
Posted 14 October 2021 - 01:50 AM
Hi fellas, what's causing those horizontal lines in this image I took? The lines are obvious in the lighter areas.
Edited by mannys, 14 October 2021 - 02:12 AM.
#2 james7ca
james7ca
  • Loc: San Diego, CA
Posted 14 October 2021 - 02:30 AM
Difficult to tell given the really small size of your enclosed image. Note that CN will resize and/or recompress your image if it is larger than 1600 x 1200 pixels or larger than 500KB. So, if that is what happened you need to resize and/or recompress your original beforehand so that it will fall under those limits.
#3 mannys
mannys
Posted 14 October 2021 - 01:58 PM
Here's a cropped version of the image. What's causing those horizontal lines?
#4 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 14 October 2021 - 02:14 PM
What light source are you using for your flats?
#5 mannys
mannys
Posted 14 October 2021 - 02:16 PM
The light source I used to obtain flats was my Mac iPad, and covered the dew shield with a white shirt.
Edited by mannys, 14 October 2021 - 02:18 PM.
#6 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 14 October 2021 - 02:18 PM
OK... reason I asked was because some panels will exhibit similar patterns if you're shooting too short a flat. Basically, you're catching the panel's refresh rate.
#7 mdavister
mdavister
  • Loc: Pennsylvania
Posted 14 October 2021 - 02:23 PM
Next follow on question, what exposure length are you using for the flats? I assume you are also doing bias frames for calibration.
#8 mannys
mannys
Posted 14 October 2021 - 02:29 PM
Hmmm. I used APP and if I remember correctly, I chose "automatic" for exposure length, letting APP determine the best length. I don't recall actually setting the length of time.
#9 charles.tremblay.darveau
Posted 14 October 2021 - 02:31 PM
Can you upload your master flat and see if the artefacts are there?
#10 mannys
mannys
Posted 14 October 2021 - 02:33 PM
Oh, so instead of choosing "automatic", I should choose a specific length of time then? I also understand that the histogram should show the light curve to be somewhere in the middle. While shooting the flats with a manually chosen exposure length, where do I go in APP to see the histogram? In using "automatic", I assumed that APP will use the correct exposure length to get the light curve to be in the middle of the histogram.
#11 mdavister
mdavister
  • Loc: Pennsylvania
Posted 14 October 2021 - 02:35 PM
I would guess that since you are using a tablet for a flat source, it would likely be short exposures. When you get into the under 20ms exposures, you start getting LED flicker and sensor read. I have noticed with the modern CMOS sensors, there is banding in the image (it can be calibrated out) under certain read conditions.
#12 mannys
mannys
Posted 14 October 2021 - 02:46 PM
Sorry, not familiar yet with APP. I'm looking at the files in my working directory, but can't tell which one is the master flat. I don't see any files that has "flat" on it. What part of the file name should I be looking for in order to identify which one is the master flat?
#13 mannys
mannys
Posted 14 October 2021 - 02:49 PM
Ok, I'll cook up another set of flats with exposure length of greater than 20ms. How do I view the flat histogram after I take test shots to make sure the light curve is within the center of the histogram?
#14 charles.tremblay.darveau
Posted 14 October 2021 - 05:15 PM
The master flat is the integration of all individual flats done in post-processing. If you only shot 1 flat then that would be you master flat and shooting multiple frames may help smoothing the artefact. Some screens have refresh latency that show as jailbars.
I have been using a cheap LED tablet from Amazon:
https://www.amazon.c...e?ie=UTF8&psc=1
Then you can tape an acrylic slab on top which acts as light diffuser. No issue with jailbars since.
  • mannys likes this
