New dome: How to do
8 replies to this topic
#1 Chris_EDNC
Chris_EDNC
Posted 14 October 2021 - 04:53 AM
I am planning to build an observatory.
Telescope is a C14 on CGX-L. It is controlled by NINA, and the dome should also be controlled by NINA.
The dome should have a gap, which of course has to follow the scope (NexDome, ExploraDome...).
General question: Does NINA know which side the telescope is on (Side of Pier)?
How should I best approach the project?
Chris
Edited by Chris_EDNC, 14 October 2021 - 05:01 AM.
#2 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 14 October 2021 - 05:00 AM
Yes, NINA will know which side of the pier the scope is on.  You will have to tell it (one time only) the exact dimensions of your scope/mount combination relative to the centre of the dome.  Obviously, you won't know those until after the dome is installed and the scope is mounted on the pier.  Using that information, it will be able to calculate the dome azimuth necessary to place the slot in front of the scope.
  • Chris_EDNC likes this
#3 Chris_EDNC
Chris_EDNC
Posted 14 October 2021 - 05:20 AM
Wow this sounds very good to me! :) :)
Any recommendations for a dome maybe also available here?
#4 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 14 October 2021 - 06:38 AM
I am happy with my 8' Exploradome.  I can mount my C-11 in it with no problem.  A C-14 will fit, but it might be getting a bit cozy.
#5 ghilios
ghilios
  • Loc: New York, NY
Posted 14 October 2021 - 08:14 AM
Hi Chris, I am the contributor who implemented the dome support on NINA. Come find me in Discord if you run into issues or have questions as you set up.
Good luck on your obsy build!
#6 Chris_EDNC
Chris_EDNC
Posted 14 October 2021 - 04:06 PM
Thats a very nice offer, thank you so much.
What components I need, for example if I use a Nexdome like you?
- Rotation kit
- Shutter motor kit
- And then how to connect to NINA?
Chris
#7 ghilios
ghilios
  • Loc: New York, NY
Posted 14 October 2021 - 05:57 PM
All you'll need to do is install the ASCOM driver and software it comes with. You can find the instructions here: https://www.nexdome.com/resources
#8 Chris_EDNC
Chris_EDNC
Posted 15 October 2021 - 01:37 AM
Perfect, now I understand the principle. :)
Chris
#9 Omeganon
Omeganon
  • Loc: Joelton, TN
Posted 15 October 2021 - 02:15 PM
I have the full Nexdome automation kit and use NINA for my sessions. It's great. Fully automated from start to finish.
