Anyone know what this object is?
12 replies to this topic
#1 jjk1962
jjk1962
Posted 14 October 2021 - 02:52 PM
Hi All
I have been scratching my head over this one for a while and I am a bit at a loss.
What is the object close between the red lines?
My setup is:
Skywatcher 200P quattro, 8" newtonian
Skywatcher EQ6R mount
ZWO ASI 294 camera with a ZWO filterwheel.
The attached picture is about 180 exposures of 30 seconds each in Ha (I cut out the interesting region)
This is part of the Butterly nebula close to Sadr. The black trapezium shaped object on the left is Barnard 347, a dark dust cloud.
The star right above this object is Gaia DR2 2067351863341990528 which is at
RA 20h 30m07.5s   DEC +40°19'49.3"
Whereas the other stars are fairly round (still working on that) and crisp, this object is quite fuzzy.
It is also visible in https://stellarium-web.org/ , and it looks the same too. Same goes for the digitized sky survey images from World Wide.
And it is not in the Gaia database eventhough its neighbor and other stars that are apparently less bright than this one.
I also have a green channel image in which this object is a lot less bright which would indicate that this thing is pretty red.
Tonight I'll collect the red data and tomorrow the blue which would give a better idea of its color
Jan Jitze Krol
#2 jjk1962
jjk1962
Posted 14 October 2021 - 02:55 PM
 Hmm, my image did not show up
JJK
#3 Jim Davis
Jim Davis
  • Loc: Lewisberry, PA
Posted 14 October 2021 - 02:59 PM
JJK
Did you do all three steps: Browse; Attach this file; and Add to post?
#4 Sky King
Sky King
  • Loc: Arizona
Welcome! To attach an image: Reply, More Reply Options, Attach Files, Choose File, Attach this file, Add to Post, Add Reply, - Must be under 500 kb, Use Paint to Resize to < 500kb if needed.
Or upload to your Gallery and Add to Post: Click on jjk1962 in upper right page corner, go to My Gallery, choose upload on the right, finish the upload process, then go to Reply to topic and pick My Media to the right of smile image , Gallery Images, click on image, Finished, post.  These are the only two ways to import media to a post that I know of.
Edited by Sky King, 14 October 2021 - 04:02 PM.
#5 jjk1962
jjk1962
Posted 14 October 2021 - 03:07 PM
#6 jjk1962
jjk1962
Posted 14 October 2021 - 03:08 PM
Wow, it worked, and folks are actually replying !
Anywho, I think I forgot the 'add to post' step and my original iamge was a couple MB in size.
Thanks guys!
JJK
BTW, this is the bigger image and you'll see some coma at the edges. Still working on the right back focus
sadr 2 Ha 2
Edited by jjk1962, 14 October 2021 - 03:20 PM.
#7 Jim Davis
Jim Davis
Posted 14 October 2021 - 03:28 PM
Well, plate solved it but it wasn't identified as anything
https://nova.astrome...43620#annotated
#8 jjk1962
jjk1962
Posted 14 October 2021 - 04:01 PM
I do understand that there are tons of stars out there that have not yet been cataloged, but this one's appearance is what throws me off.
Plus it is big and bright enough to be calaloged I would think.
Here are some more pictures to highlight what I mean by 'appearance'
This is a crop of the main stacked image around the star in question.
And this is also visible in one of 200 the raw images:
Edited by jjk1962, 14 October 2021 - 04:02 PM.
#9 spacemunkee
spacemunkee
  • Loc: Cincinnati, Ohio
Posted 14 October 2021 - 04:09 PM
Doesn't appear to be a star to me, else you would expect it to be a sharp bright circle as are the stars of similar size.
I will be curious as to the answer.
  • Sky King likes this
#10 D_talley
D_talley
  • Loc: Albuquerque, New Mexico
Posted 14 October 2021 - 04:51 PM
I am thinking that it is a small planetary. What is the number to Hubble control? smile.gif
  • jjk1962 likes this
#11 StanH
StanH
Using the Aladin V11.0, it identified it as the planetary nebula Sd 1 and directed to SIMBAD https://simbad.u-str...ent=PN Sd 1
Edited by StanH, 14 October 2021 - 04:52 PM.
  • maroubra_boy, RazvanUnderStars, Sky King and 1 other like this
#12 jjk1962
jjk1962
Posted 14 October 2021 - 05:08 PM
Oh, awesome!! Thanks Mariner!
So now I need to take a look at Aladin ;-)
Thanks again guys
JJK
#13 ButterFly
ButterFly
Posted 15 October 2021 - 05:02 PM
SIMBAD Coordinate Query is a good place to start.  It shows the AlladinLite view of the desired search radius over on the right side.
