ETX-125 PE RA problems
Polar Alignment Meade
3 replies to this topic
#1 Marcushope
Marcushope
Posted 15 October 2021 - 12:34 PM
I have a Meade ETX-125 bought about 2007. Recently the RA drive has given problems with set up, running into the stops. Now the telescope will only turn 312 degrees by hand rather than the 2 1/2 revolutions.  Meade USA cannot help, Meade UK (I live in London) have not imported these telescopes and have no spares.
I saw a video about dismantling the base plate of the ETX to access the motor drive, but I believe the RA ring is located on the other side (ie underneath the motor as seen from the opened base. Is this correct? And has anyone tried to correct this problem?
Needless to say the optics are wonderful: pity about the drive.
#2 OzAndrewJ
OzAndrewJ
Posted 15 October 2021 - 04:11 PM
Gday Marcushope
If it is a true "PE" model, then i wrote a document on disassembling them to fix severe binding.
http://www.weasner.c...f_ETX125PE.html
It shows piccies of the mechanism, ( which is pretty simple ), but its a beast to get to
and involves a lot of disassy to get the clutch bolt free without cutting wires.
One recent user had a similar problem and it came back to the fact one of the screws
holding the plastic motor assy in place
had been screwed in too far and was snagging the moving stop disk.
Edited by OzAndrewJ, 15 October 2021 - 04:16 PM.
#3 Marcushope
Marcushope
Posted 17 October 2021 - 10:26 AM
Hi Andrew,
My reply to you and your helpful rejoinder have mysteriously disappeared. Maybe I am navigating the forum incorrectly, so could you kindly repost as I had a further question: the stop which might foul the plate is a screw, I presume. If so what size Allen key is required?
Marcushope
#4 OzAndrewJ
OzAndrewJ
Posted 17 October 2021 - 03:54 PM
Gday Marcus
You sent the request for specifics as a private message ( not on the main forum )
and my reply is on that ( and its still there )
Also tagged with one or more of these keywords: Polar Alignment, Meade
