Alternative bases/riser for Telrad
Equipment Accessories
11 replies to this topic
#1 Brenden
Brenden
Posted 15 October 2021 - 09:41 PM
Hi everyone,
I have an ES truss dob and just purchased a telrad to install. Unfortunately the base is about 1 cm too long and doesn't fit between metal rings on the upper assembly. I have found the dove tail adapters on scope stuff, but they are pricey and I already have a RACI finder attached so I would rather find another option. Are there any alternative bases out there or even a riser that have a slightly smaller (less long) footprint? I love the quality of the telrad, but I suppose if I can't make it work then I will return it in exchange for a Rigel quick finder.
#2 Avgvstvs
Avgvstvs
  • Loc: Australia
Posted 15 October 2021 - 09:50 PM
Its hard to tell from your description but can you put a small wooden block
between your metal rings? Then mount the telrad base on top of that?
It doesn't matter if it overhangs a bit on either side. But maybe it won't look so good?
I guess it all depends on what's important to you.
#3 kfiscus
kfiscus
  • Loc: Albert Lea, MN, USA
Posted 15 October 2021 - 09:52 PM
I'm not familiar with the ES scope.  How high are the rings that you need to clear?  My thought was attaching a wooden block to serve as a cheater/base for attachment of the Telrad base above the rings.
(Posted moments after the above similar suggestion made while typing.)
Edited by kfiscus, 15 October 2021 - 09:54 PM.
  • Avgvstvs likes this
#4 Brenden
Brenden
Posted 15 October 2021 - 10:08 PM
The rings are very low, maybe about 2mm. The tube is long enough, there's just not quite enough room between the two rings that go around it. Using a piece of wood is a good idea. I don't have access to a shop to cut something to size, but maybe I can find something else to use. The only issue I see is that it might not stay very well due to the curve of the tube (The telrad has two angled points of attachment).
#5 kfiscus
kfiscus
Posted 16 October 2021 - 01:13 PM
You could have someone cut a piece of aluminum U-channel.  Mounted 'upside-down', its 2 edges will keep things aligned.
#6 Mitchell M.
Mitchell M.
  • Loc: Mountains of Western NC
Posted 16 October 2021 - 03:17 PM
How about mounting the telrad to the raci in such a way to utilize them together?
#7 BNesvold
BNesvold
Posted 17 October 2021 - 06:52 PM
I had the same issue with the same scope. I trimmed off the bottom couple millimeters on one end of the telrad base until the it fit between the upper and lower rings on the UTA.
  • Jon Isaacs likes this
#8 Jon Isaacs
Posted 17 October 2021 - 08:07 PM
Hello and :welcome: to Cloudy Nights..
That sounds like the plan..
#9 Brenden
Brenden
Posted 19 October 2021 - 11:48 AM
I also thought about trimming it slightly, but am lacking in trimming tools. Perhaps I will look into this though. What did you use to trim it?
#10 cliff mygatt
cliff mygatt
  • Loc: Kitsap County, WA
Posted 19 October 2021 - 01:52 PM
I have an ES 16 gen II dob and I use this bracket to mount both my Telrad and Stellervue 60 mm Finder scope and works well.  I have to adapt the bracket to ES.  I use this Telrad adapter from Scopestuff and this riser as well.  The finder is closest to the Focuser and forward in the mount and the Telrad is on a short riser and back in the mount.  Good luck!
Edited by cliff mygatt, 19 October 2021 - 01:58 PM.
#11 kfiscus
kfiscus
Posted 19 October 2021 - 09:37 PM
I would use a Dremel and a sanding drum with a light touch (and eye protection).
#12 BNesvold
BNesvold
Posted 20 October 2021 - 07:13 AM
I just used a hack saw. Mark the cuts and take it slow.
Also tagged with one or more of these keywords: Equipment, Accessories
