[SOLVED] Problems connecting QHY camera
11 replies to this topic
#1 Luca Amerio
Luca Amerio
Posted 16 October 2021 - 06:45 AM
EDIT: SOLVED. See the solution at the end of this post.
Hi everybody
I'm moving my first baby steps in the world of CCD/CMOS astronomy after few years using a DSLR PC-free setup.
I recently bought a QHY163M camera (and a QHYCFW) but I'm having some issues having the camera detected by my PC.
I installed the ASCOM platform 6.5.
I downloaded the SYSTEM PACK Ver.201910 from QHY website https://www.qhyccd.com/download/. From there I installed:
- QHYCCD Device Drivers
- EZCAP
- ASCOM DRIVERS (for platform 6.5)
- ASCOM DRIVERS CFW
- SharpCap
However when I connect the camera to the PC (after hearing the "dling" sound) neither EZCAP, nor SharpCap detect the camera.
More precisely...
EZCAP simply states "Not Found QHYCCD devices"
SharpCap detects the camera using the ASCOM drivers, but not with QHY native drivers:
If I select QHYCCD-Cameras-Capture I receive first this warning
and then this error:
(The details of the error translates to something like: "Access point not found". Don't know why that part is in Italian)
If I select QHYCCD-Cameras2-Capture instead nothing changes.
Lastly I went to Device Manager to check if the system was detecting the camera. I found that the camera is detected as "WestBridge" (100% sure it's her) but the drivers appear to be missing.
And I'm stuck here...
Any suggestion?
SOLUTION
While installing the QHY drivers DO NOT REMOVE the tick for QHY5III Camera driver when selecting "Additional Tasks". Those are exactly the drivers you need for the latest (2021) cameras as QHY163.
Edited by Luca Amerio, 16 October 2021 - 09:58 AM.
  • AstroNikko likes this
#2 Bob Koch
Bob Koch
  • Loc: Broken Arrow, OK
Posted 16 October 2021 - 07:13 AM
Are you appling 12v power to the camera?
  Bob
#3 Luca Amerio
Luca Amerio
Posted 16 October 2021 - 07:28 AM
  Bob
Edited by Luca Amerio, 16 October 2021 - 07:28 AM.
#4 tucsondave
tucsondave
Posted 16 October 2021 - 07:49 AM
I have a QHY294C and had the same problem, complete with "ding", when I used an extension USB cable that was not 3.0.  After upgrading to a 3.0 cable, SharpCap recognized the camera for native use.
Also used a powered USB 3.0 hub to connect scope and camera to computer.
td
Edited by tucsondave, 16 October 2021 - 07:55 AM.
#5 Astro Gerard
Astro Gerard
Posted 16 October 2021 - 08:07 AM
I had the same problem because I unchecked what I thought were old camera versions. You must accept All defaults listed when it shows what appears to be older models upon installation of the software- they are actually the ones you need.
Edited by Astro Gerard, 16 October 2021 - 08:08 AM.
#6 Luca Amerio
Luca Amerio
td
Thanks for the hint, but I’m using the usb3 cable that came with the camera directly to the pc. I have a usb3 hub, but to exclude the problem was that one I bypassed it at the moment.
I’m quite sure the usb on my pc is a usb3. Any idea on how to verify that?
#7 dghent
dghent
  • Loc: Maryland, US
Posted 16 October 2021 - 08:10 AM
The Device Manager screenshot is the telling one here.
First off, the QHY ASCOM driver being listed does not mean that the camera hardware is detected by anything. ASCOM drivers are always present, and any application will always list the ASCOM drivers that are installed on the system. You have to manage their connection to the actual hardware from within their own configuration/setup menus. One should think of an ASCOM driver as a middleware application, not so much a driver.
As indicated by the Device Manager screenshot, it would appear that the QHY USB driver is not attaching to the camera when it's plugged into your system, likely due to some issue with either the USB driver's installation or Windows itself is confused and doesn't know which driver to attach to the camera.
To attempt to fix this, try the following:
  1. Unplug the camera from your computer, just to have it out of the way
  2. Go to Windows Settings -> Apps
  3. Search for/look for "QHYCameras Driver" - this is the QHY USB driver installation package
  4. Uninstall QHYCameras Driver
I would reboot your system at this point, just to ensure than any mis-installed driver is no longer in Windows' driver cache.
  1. ​Go to the QHY USB driver download page and download the current one, listed at the top
  2. Unzip the file. There will be 2 larger files inside; one for Windows 7/8, the other for Windows 10.
  3. Run the Windows 10 installer, assuming you are using Windows 10.
  4. CLick through all the default options and finish the installation
At this point, you should be able to connect your camera and the QHY USB driver should attach to it. You would then see it listed under the Cameras menu in SharpCap, as well as in the configuration/setup window of the QHY ASCOM driver.
  • Luca Amerio likes this
#8 Luca Amerio
Luca Amerio
Posted 16 October 2021 - 09:53 AM
Thank you so so much dghent
At the end of the day I understood my mistake. Reading around I understood that QHY product with a single digit (as QHY5II, QHY8, QHY9, etc) were obsolete product. So in the driver window I removed the tick from the drivers for the QHY5III series foreheadslap.gif
Following your instructions (and keeping the drivers for QHY5III ticked) now the camera is correctly working in EZCAP, SharpCap and it's correctly listed in Device Manager.
Thank you very much for your detailed instructions and for pointing me in the right direction. bow.gif
  • dghent and AstroNikko like this
#9 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 16 October 2021 - 11:23 AM
Glad you got that sorted out.
#10 dghent
dghent
  • Loc: Maryland, US
Posted 16 October 2021 - 11:56 AM
Yes, that would be the root cause of this issue, then.
The product nomenclature is a little strange and has, I think, historical reasons for its structure, but "QHY5III" covers all USB3 CMOS cameras, cooled and uncooled.
#11 AstroNikko
AstroNikko
Posted 30 December 2021 - 10:48 PM
I did this exact same thing. I didn't realize the QHY268 is a QHY5III series camera and unchecked the driver, as well as all the others in the list. Thank you so much for sharing!
#12 pbkoden
pbkoden
Posted 11 January 2022 - 06:16 PM
Another thank you for this. I updated my drivers and didn't check that box. My 268m failed to connect and no matter what I did I couldn't get it working until I found this thread. Such a poorly labeled dialog box!
You saved me a few more grey hairs.
