Polar aligning in sharpcap with main cam
4 replies to this topic
#1 damarks913
damarks913
Posted 16 October 2021 - 06:44 PM
Today's noob question...
Can you do sharpcap polar alignment using the main cam, in this case a qhy168c?
  • Rams likes this
#2 Mark Lovik
Mark Lovik
Posted 16 October 2021 - 07:41 PM
I do it all the time.  I use short subs and guiding is not necessary (not limiting) for my system. There are some constraints to this.
1. Primary sensor has at least 0.5 degree field of view ... Sharpcap constraint.
2. You can adjust your polar alignment with the added weight of your optics train.  This is a mount constraint.
Edited by Mark Lovik, 16 October 2021 - 07:44 PM.
  • dswtan likes this
#3 astrohamp
astrohamp
  • Loc: Massachusetts
Posted 16 October 2021 - 07:43 PM
My current mounted OTA is a newtonian with 0.85x0.58 degrees FOV and SharpCap 4.0 64 bit is fine with polar alignment.  My 1.11x0.76 degree FOV refractor had no problems either.
I do make sure I start the alignment at least 3 degrees East (or west) then move at least 3 degrees the other side to complete the alignment process.
  • asf likes this
#4 ChiTownXring
ChiTownXring
  • Loc: Sugar Grove, IL
Posted 16 October 2021 - 11:14 PM
I use an OAG so when I do want to double check my PA I use my main camera the ASI1600MM-Pro in SharpCap and it works perfectly. But I do have 3 marks on my deck so I just place my tri-pod down on the marks and use my polar scope 9 out of 10 imaging sessions and I average around 0.45 RMS..
Edited by ChiTownXring, 16 October 2021 - 11:15 PM.
#5 Rams
Rams
Posted 17 October 2021 - 09:18 AM
Thanks for posting.. I have the same question.
I have a 130 mm newtonian..
Edited by Rams, 17 October 2021 - 09:18 AM.
