CEM70, UB cable falls out/loses connection
3 replies to this topic
#1 FloidPienk
FloidPienk
  • Loc: Hoegaarden (Belgium) and Thoiry (Ain, France)
Posted 17 October 2021 - 12:36 PM
Sometimes the USB cable in the USB port on the rear RA axl of the CM70 loses connection, or 'almost' falls out of it.  It just does not stick enough.
Is there anybody who has experienced the same, or, much beter, has an idea for a solution for this?  Rather annoying if one loses in the middle of the night all gear...
#2 FloidPienk
FloidPienk
Posted 27 October 2021 - 05:16 PM
Solution was to bUy way better and more expensive cables :
https://www.allekabe...b-20-kabel.html
Edited by FloidPienk, 27 October 2021 - 05:58 PM.
  • OldManSky likes this
#3 EmeraldHills
EmeraldHills
  • Loc: Louisville, Kentucky
Posted 27 October 2021 - 08:03 PM
Use one of these, stuck to the base plate of the mount. Clip the cable in with a "drip loop" that takes all pressure off the plug.
https://www.amazon.c...duct/B076WXRN28
#4 OldManSky
OldManSky
  • Loc: Valley Center, CA USA
Posted 28 October 2021 - 10:37 AM
Get one of these:  https://www.amazon.c...35435364&sr=8-5
Pick the size you want.
They will "snap" into place with a very satisfying "click," and stay in place.  You can doubly protect the connection if you use one of Doug's cable holders above, as well.
Been using the JSAUX cables for all my USB connections for a couple of years now.  They all snap tightly in place, and have had no failures, including the one from my main USB3 hub to the rear port on my CEM60.
