Poor Quality of Planetary Images
Celestron Imaging Planet Software
4 replies to this topic
#1 sandconp
sandconp
  • Loc: Minnesota USA
Posted 18 October 2021 - 08:36 AM
I have noticed recently that I am not get the quality image of Jupiter and Saturn that I used to get.  I went back and compared my SER files and I noticed that the better quality image is (GBRG) and has a very low frame rate of 3 FPS.  The poorer quality image is (BGR) and I am getting 130 FPS.  This does not make any sense to to me because you would think I would be getting a better quality image which is at a higher frame rate?  The only other difference is I was running 3.2 vs 4.0 of Sharpcap Pro and the fact the SER file is showing up as (GBRG) vs (BGR).
Any ideas?
I am using a C8 and a C11 and a ZWO ASI178MC OSC planetary camera.
Edited by sandconp, 18 October 2021 - 08:44 AM.
#2 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 18 October 2021 - 08:43 AM
Same date of imaging ?
#3 sandconp
sandconp
Posted 18 October 2021 - 09:52 AM
No about a year apart.
#4 WarmWeatherGuy
WarmWeatherGuy
  • Loc: Las Cruces, NM 32° N, 107° W
Posted 18 October 2021 - 09:57 AM
There are 4 pixels per group and two of them are green. The possible combinations are GBRG, GRBG, RGGB, and BGGR. The two greens are always diagonally opposite so you won't see GGRB or GBGR for example. Each of the possible combinations can be uniquely identified by using just the first 3 letters because you can deduce the 4th letter by what's missing (R, B, or the second G).
If you have BGR then that would be the same as BGRG which would have the two green pixels in the same column which is unlikely. I'm hoping you meant to write GBR which would be the same as GBRG.
If you had the rare 3 sigma good seeing when you took those 3 FPS videos then that would account for why they are better quality.
#5 David Boulanger
David Boulanger
  • Loc: Naples, Florida
Posted 18 October 2021 - 10:24 AM
the 178 is a RGGB camera.
Also tagged with one or more of these keywords: Celestron, Imaging, Planet, Software
