CEM70 Untracked / Tracked performance
5 replies to this topic
#1 aarshad81
aarshad81
Posted 19 October 2021 - 11:40 AM
Hi there, was wondering what kind of performance you are getting from your CEM70. I have a AT115EDT 644/805mm focal length depending on reducer/flattner, noticing untracked I only tried till 60 seconds, i had some drift going to 120seconds
I will soon have some better data including tracked numbers
#2 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 19 October 2021 - 11:59 AM
Do you know how accurate your polar alignment is, as that can contribute to drift in both axes?
#3 bobzeq25
bobzeq25
Posted 19 October 2021 - 01:20 PM
I presume you mean guided/unguided.
I fail to see why people don't want to guide.  The periodic error of your mount is about 8 arc seconds, peak to peak (and it will not be reduced with good polar alignment).  Even mediocre guiding will reduce that to below 1 arc second rms.
Why would you want to throw away that improvement?  You worry about _much_ smaller things.  You might as well have gotten a less expensive scope, the quality of the AT115EDT is being wasted.
If your skies are dark, 60 second subs are too short.
If you really insist on unguided, you need a better mount, and it needs to be on a fixed pier.  Something like a 10Micron in an observatory.  <smile>
Edited by bobzeq25, 19 October 2021 - 01:22 PM.
  • Tony Bonanno and OldManSky like this
#4 Tony Bonanno
Tony Bonanno
  • Loc: Santa Fe, New Mexico
Posted 19 October 2021 - 01:50 PM
I have the same scope (AT 115 EDT) on my CEM70 set up for imaging.
I tried unguided with good polar alignment, just once for kicks.  With 30 sec subs, it was fine.  60 sec subs, I noticed a little distortion in stars, possibly could be better if I'm more careful with setup, balance, PA, etc.
But generally I always use guiding.  With guiding enabled, no complaints at all.  Even with 5 min subs, stars are pretty good.  Typically, I just use 120 second subs.  Guiding is the way to go for sure.
Edited by Tony Bonanno, 19 October 2021 - 01:57 PM.
#5 aarshad81
aarshad81
Posted 19 October 2021 - 02:46 PM
O for sure i am going the route of guiding, but was just wandering what to expect from a mount like this. Since i got the mount it started raining/cloudy for the  next week and half lol
I only had a short window to try some stuff out and just used it unguided.
  • Tony Bonanno likes this
#6 aarshad81
aarshad81
Posted 19 October 2021 - 02:47 PM
Thanks cool !
