Missing Machine Screw on Vixen GP Mount wooden Leg Dividers
5 replies to this topic
#1 saemark30
saemark30
Posted 19 October 2021 - 12:28 PM
Missing screw and nut on Vixen GP mount. Can someone tell me what size and length are the screws that connects the plastic dividers together?
#2 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 19 October 2021 - 12:49 PM
Can you show us a picture of exactly what ****'re missing?
Clear skies!
Thomas, Denmark
#3 saemark30
saemark30
Posted 19 October 2021 - 01:22 PM
vixen-gp-great-polaris.jpg Here is an image. The 3 black plastic brace the wooden legs. I am missing one of the bolts or screws that holds one of them at the center.
#4 lphilpot
lphilpot
  • Loc: Central Lousiana, USA
Posted 19 October 2021 - 01:39 PM
Can you take one of the other screws to a hardware store and find a suitable (if not identical) replacement? I suspect the actual threading doesn't matter except for the nut that presumably holds it in place. Just get a suitable diameter and length bolt with a matching nut and a couple of washers.
#5 jurdea
jurdea
  • Loc: Centennial, CO
Posted 19 October 2021 - 01:59 PM
If you go to the hardware, head to the metric bolts and nuts as Vixen's are all metric
#6 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 19 October 2021 - 02:03 PM
Is that the one that is a pin with 2 C-clips? If so good luck finding anything like that at a DIY store. Best substitute is an appropriate size screw with a Nylock nut on the other end to give it a small gap to rotate. Only way I know to find the original part is to find another one to cannibalize.
Ok you need one of the center arm bolts. Take one of the others to a store and look.
Edited by photoracer18, 19 October 2021 - 02:05 PM.
  • Castor likes this
