dome over sea container
12 replies to this topic
#1 DENISANNA
DENISANNA
  • Loc: Campbellton, New Brunswick Canada
Posted 20 October 2021 - 10:00 PM
as anyone have thoughts about putting a motorized polyprop type dome like SkyShed Pods makes over the roof of a 20 feet sea container ? My sea can is already divided inside to isolate the weather and am working on a roll off roof idea but ain't quite sold on that idea yet !!! The idea of a dome came to me after seeing a few domes beings sold on this site!!
#2 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 21 October 2021 - 08:50 AM
My first thought is you will need a tall pier. And a stepladder to adjust the scope.
  • archer1960 likes this
#3 archer1960
archer1960
  • Loc: Southern New England
Posted 21 October 2021 - 10:11 AM
Or a platform that goes around the pier at the proper height.
#4 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 21 October 2021 - 02:48 PM
Up periscope!
#5 Stevegeo
Stevegeo
  • Loc: Otisco lake. Marietta NY 13110
Posted 21 October 2021 - 04:17 PM
The only issue I see and it a minor one is some containers have ribbed tops . Either a flat roof with the dome sitting on that , OR dome ring support would need to be sealed in the valleys .... a major pain .
Cutting the circle done with a torch , or plasma cutter ( ideal) would be best .
Previous mention of a platform  ,  with a pier through the center , stairs to platform ,storage under platform or utilities ( heater, water tank, electrical , cabinets...  I could see it as an ideal observatory.
Just my two cents .
Stevegeo
#6 DENISANNA
DENISANNA
Posted 21 October 2021 - 05:25 PM
agree!!! just building a circular/square platform raised 3 feet from the floor with an internal step latter is only a wee project !!! the idea of being able to stick my head inside the dome make's it more exciting so access to the telescope/mount with a diameter of 6 feet, i think is ok, what are your thoughts ???
#7 DENISANNA
DENISANNA
Up periscope!
ramming speed Captain !!!
#8 DENISANNA
DENISANNA
Posted 21 October 2021 - 05:30 PM
Just my two cents .
Stevegeo
What are your thoughts on a circular mobile platform on wheels, using the edges with a tubing rail as to pull around the pier/mount/telescope ?
#9 archer1960
archer1960
Posted 21 October 2021 - 05:45 PM
Just my two cents .
Stevegeo
Yup!
#10 archer1960
archer1960
Posted 21 October 2021 - 05:46 PM
That is basically what my local observatory (Frosty Drew Observatory) in RI does. It works great.
#11 jcj380
jcj380
  • Loc: Hellinois
Posted 22 October 2021 - 09:27 AM
I've read a fair amount about using containers for tiny houses, cabins, observatories.  A common thread is the roofs are not made to handle a heavy load, so bracing might be needed.  YMMV.
#12 555aaa
555aaa
    Vendor (Xerxes Scientific)
  • Loc: Ellensburg, WA, USA
Posted 23 October 2021 - 09:27 AM
They make open top shipping containers.
#13 DENISANNA
DENISANNA
Posted 23 October 2021 - 06:18 PM
Now that my pier/mount setup is in progress, i can imagine it to completion !! The idea of a rotating platform around my pier is a very realistic idea that has my endorphins flowing !!! we'll see ... The cut out hole in this can's roof is 6'x6', reinforced by 1/4" 2" angle iron welded into the outer frame, the load bearing is well designed for this exact project as long the dome's weight is within reason !! Also am waiting a bit before cutting my hole in the roof as winter is soon upon us and would like to find a used dome and modify the mounting as to cut the hole and weld a steel ring as to meet this eventual dome .
I would like to pass the mike to anyone to reply !!!!
