Very first attempts at planets
11 replies to this topic
#1 Markinspace
Markinspace
Posted 20 October 2021 - 11:36 PM
These are my very first attempts.  I used an old Meade Barlow to get some image scale. I’ve got a ways to go but happy with this start.
Question, I’m using an old laptop for these, any recommendations for a newer one with enough power and  memory to take multiple imaging runs without shutting down the laptop?
TAK 130, ZWO 462, 2x Barlow.
  • Dave Mitsky, zjc26138, Sunspot and 26 others like this
#2 Kiwi Paul
Kiwi Paul
  • Loc: Carterton, New Zealand
Posted 21 October 2021 - 12:52 AM
That's a very good start.
Most people on this forum will tell you don't need to have the very latest laptop to do imaging with. If you are able to record images at speeds of say 100 to 150 frames per second then you are doing well. Of course you need to have the storage on your laptop - solid state storage is preferred to disk drives because of the writing speed. The other thing to ensure high frame rates, is the region around your target (ROI - region of interest). Try and make this as small as your mount tracking will allow. This helps keep frame rates up and allow you to collect more frames for stacking.
I'm sure you have a ton of other questions.
Cheers Paul
  • ziggeman likes this
#3 astro rocketeer
astro rocketeer
  • Loc: Valencia, CA (Los Angeles)
Posted 21 October 2021 - 01:09 AM
Congrats! Thats excellent for your first planetary image!! Keep it up
#4 David Boulanger
David Boulanger
  • Loc: Naples, Florida
Posted 21 October 2021 - 05:23 AM
Very nice first images.
#5 Markinspace
Markinspace
Posted 21 October 2021 - 12:40 PM
Cheers Paul
So my laptop says my C drive has like 651GB available and 5.88GB of memory.  It was able to record a two-minute run of Saturn which saved to my C drive,  but when I switched to do same run at Jupiter the laptop crashed.  I think I was out of memory??
#6 Borodog
Borodog
Posted 21 October 2021 - 12:57 PM
Did you reduce the Region Of Interest (ROI) before capturing? It doesn't look like you did. That will radically increase the memory requirements, IO throughput requirements, file size, and processing time, and possibly significantly decrease frame rate.
Nice first images, by the way. All they need is to be brightened up.
#7 Markinspace
Markinspace
Posted 21 October 2021 - 11:13 PM
Tried some alternative processing.
  • vilchez likes this
#8 adlartok
adlartok
  • Loc: Fort Worth, Texas
Posted 21 October 2021 - 11:14 PM
wow....very good first images, you should be proud of them
#9 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 22 October 2021 - 10:03 AM
Lack of java heap for FireCapture will not cause the laptop to crash. This sounds more like a USB driver issue.
#10 cigtech
cigtech
  • Loc: Dallas
Posted 22 October 2021 - 10:09 PM
I like the way you brought out the details in your 2nd processing of Jupiter. good work
#11 Markinspace
Markinspace
Posted 22 October 2021 - 10:56 PM
Thanks Apollo!
#12 Dave Mitsky
Dave Mitsky
  • Loc: PA, USA, Planet Earth
Posted 22 October 2021 - 11:31 PM
Well done!
