224 MC flicker while recording
Astrophotography
7 replies to this topic
#1 Kaiserbill
Kaiserbill
  • Loc: Harrisburg, PA
Posted 21 October 2021 - 11:41 AM
Hey...
I've had my 224MC for about three years now and have had great success with it. Just recently I noted that while recording videos there is a significant 'flicker' as if a cable is loose. Well as I am very wise I changed out my USB to C adaptor for my laptop. No change. Below is an image of a the SER from PIPP.
What is the story?
#2 rkinnett
rkinnett
  • Loc: La Crescenta, CA
Posted 21 October 2021 - 12:04 PM
My guess is usb overflow.  Check your usb traffic setting.  Which software did you use to capture, and what were your settings?  If you used FireCap, it's helpful to post your settings file.  Did anything change in your physical usb configuration?
#3 Kaiserbill
Kaiserbill
Posted 21 October 2021 - 01:55 PM
I am using CPWI and SharpCap; no change in my settings. USB is 3.0. I see I have high speed mode on and turbo at 100. I just turned High speed mode off and turbo down to 80. It seems to have helped as I image my ceiling,lol.
[ZWO ASI224MC]
FrameType=Light
Debayer Preview=On
Pan=2
Tilt=0
Output Format=SER file (*.ser)
Binning=2
Capture Area=1304x976
Colour Space=RAW8
Temperature=22.8
Hardware Binning=Off
High Speed Mode=On
Turbo USB=100(Auto)
Flip=None
Frame Rate Limit=Maximum
Gain=126
Exposure=15.2460ms
Timestamp Frames=Off
White Bal (B)=80
White Bal ®=55
Brightness=14
Auto Exp Max Gain=238
Auto Exp Max Exp M S=22417
Auto Exp Target Brightness=71
Mono Bin=Off
Background Subtraction=Off
Planet/Disk Stabilization=On
Banding Threshold=35
Banding Suppression=0
Apply Flat=None
Subtract Dark=None
Display Black Point=0.046875
Display MidTone Point=0.243943851534626
Display White Point=0.80859375
Notes=
TimeStamp=2021-10-21T02:40:58.6847469Z
SharpCapVersion=4.0.8185.0
StartCapture=2021-10-21T02:40:58.6812749Z
MidCapture=2021-10-21T02:42:33.2502749Z
EndCapture=2021-10-21T02:44:07.8185337Z
Duration=189.137s
FrameCount=12375
TimeZone=-4.00
#4 Kaiserbill
Kaiserbill
Posted 21 October 2021 - 02:12 PM
I just now turned OFF 'Planet Stabilization'. The flickering stopped. Hmm.
#5 cigtech
cigtech
  • Loc: Dallas
Posted 22 October 2021 - 10:11 PM
Is the camera getting hot? may be overheating
#6 Kaiserbill
Kaiserbill
Posted 26 October 2021 - 01:02 PM
The camera was not getting hot but that could’ve been a cause. I discovered. It was USB traffic. I turned high speed off and turbo off,as well as planet stabilization. All well.
I was intially convinced it was a bad cable but it was not. I am even using a USB booster.
#7 bips3453
bips3453
  • Loc: MN
Posted 26 October 2021 - 01:39 PM
Just wondering, could it be a wobble in the scope?
#8 Kaiserbill
Kaiserbill
Posted 29 October 2021 - 03:21 PM
Ranger 4, definitely no but something that could have been. Really stable set up. I'm pretty sure it was USB traffic.
Also tagged with one or more of these keywords: Astrophotography
