Updating Celestron Motorized Focuser Firmware
3 replies to this topic
#1 TonyMan
TonyMan
  • Loc: Lisle, IL
Posted 21 October 2021 - 11:42 AM
I found the picture below for updating a system with a StarSense. I wanted to check the firmware for my Celestron motorized focuser. Would I use the same setup and substitute the focuser for the StarSense?
#2 mlord
mlord
  • Loc: Ottawa, Canada
Posted 21 October 2021 - 12:22 PM
Celestron says the firmware for the Celestron Focus Motor is handled by CFM, so it should just work if you run CFM while the focuser is connected for normal use, no fancy set-up changes.
Edited by mlord, 21 October 2021 - 12:25 PM.
  • TonyMan likes this
#3 mlord
mlord
Posted 21 October 2021 - 12:23 PM
If you just want to check the version, without updating anything, then the AUX Bus Scanner can do that for you.  There's a big thread on the scanner here:   https://www.cloudyni...982&hl=+scanner
Edited by mlord, 21 October 2021 - 12:24 PM.
#4 TonyMan
TonyMan
  • Loc: Lisle, IL
Posted 21 October 2021 - 06:50 PM
