3d printed rings for refractor
3d printing
6 replies to this topic
#1 Faber
Faber
Posted 21 October 2021 - 12:34 PM
Dear all,
Have you any experience about rings for a refractor of 10cm of diameter printed instead of an aluminium ones?
They change due to heat or loads?
Thank in advance and best regards
#2 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 21 October 2021 - 01:07 PM
I do a fair amount of 3D printing, but not for this.
There are many variables, starting with the filament you use.  PLA has too low a glass temperature for me to want to use it.  Nylon should work and would certainly be worth trying, as would ABS and a carbon fiber reinforced filament could work well too.
Do you have a printer?
Do you have a design?
Plastic is more flexible, generally, for the same volume and has a much lower melting point, but a well design product should work.  I'd go composite and use metal in the fasteners and hinge pins as a minimum.
#3 Faber
Faber
Posted 21 October 2021 - 04:39 PM
I don’t have a printer.
Was a proposal of an artisan instead of alluminium.
I’m not totally convinced because the material to be used will be plastic only. For a case or something similar no problem, but for ring I think it’s necessary to reinforce the filament. At the end I decided for alluminium.
Thank for the opinion.
Regards
#4 SchoolMaster
SchoolMaster
  • Loc: Florida
Posted 21 October 2021 - 05:30 PM
Well engineered plastic is very robust and I'm sure something usable could have been created.  Aluninium is a comparatively soft metal.
Good luck.  What scope were you thinking of putting on it?
#5 iwannabswiss
iwannabswiss
  • Loc: Somewhere in Space
Posted 21 October 2021 - 05:53 PM
Dear all,
I printed a set of rings for an 8 inch scope for a friend using ABS; haven't heard any negative from him.
Edited by iwannabswiss, 21 October 2021 - 05:57 PM.
#6 Faber
Faber
Posted 22 October 2021 - 12:43 AM
A Takahashi fc 100 dl with a weight of 3-4 kg. The problem is that the tube will be used in a dual rig and i was worried about maintaining the collimation with other tube.
#7 Beeham
Beeham
  • Loc: Oakland County, Michigan
Posted 24 October 2021 - 07:20 AM
I have done a fair amount of 3d printing, and for a scope that nice, I would never trust a plastic ring made on a consumer-grade printer.  If you need something really special to fit a design requirement, I would farm it out to a CNC shop and have it cut from aluminum.
The risk of the scope hitting the pavement due to a failure of the printed rings would be too great for me to enjoy using it.
Maybe I'm paranoid, but even the stronger filaments (ABS, nylon, and PETG) have time-dependent creep and aging behavior that would worry me.
I hope that's a helpful perspective.  Good luck with your project!
  • PrestonE and Bob4BVM like this
Also tagged with one or more of these keywords: 3d printing
