Wow! Incredible night tonight!!!
I had both the Tak FC-100DC and the BT-100XL/SD out. Super super steady seeing with incredible transparency. I've NEVER seen it this good around here. Kinda makes you jealous of those with steady skies.
Boring but beautiful
Some incredible doubles, triples and systems tonight. Most at 93x (TPL 6mm). Some at 140x (TOE 4mm) and some at 296x on the telescope for verification. All were observed and split with the BT. No doubt it's harder but I made it a point to show that it can keep up!
First up:
STT 179 (Kap Gem)
07h 44m 26.87s +24° 23' 53.3" P.A. 243.00 sep 7.0 mag 3.66,10.00 Sp G8IIIa dist. 43.35 pc (141.41 l.y.)
Sort of an interesting double. Very suited for BT observation where the magnitude difference isn't such an impediment. Good solid start. I like!
HU 614 (UV Aur)
05h 21m 48.92s +32° 30' 39.8" P.A. 5.00 sep 3.5 mag 9.20,11.00 Sp CII\
Really dim. Especially the secondary. This took a while to pick up.
STT 103 (16 Aur)
05h 18m 10.56s +33° 22' 17.8" P.A. 55.00 sep 4.1 mag 4.80,10.60 Sp K3.5III dist. 71.23 pc (232.35 l.y.)
Very challenging. Really close and a significant difference in magnitude. This one was observed in the BT but I needed the telescope at 300x to confirm.
STF 948 AB (12 Lyn)
06h 46m 14.15s +59° 26' 30.1" P.A. 65.00 sep 1.9 mag 5.44,6.00 Sp A3V+A1IV dist. 65.83 pc (214.74 l.y.)
with
STF 948 AC
06h 46m 14.15s +59° 26' 30.1" P.A. 309.00 sep 8.9 mag 5.44,7.05 Sp A3V+G5IV dist. 65.83 pc (214.74 l.y.)
WOW WOW triple WOW!!!
Totally worth it for such a close double. Totally doable at 140x as well. The AB pair are big and bright and were easy to separate. The "C" star was off to the side looking dimmer. Such a rewarding system! Must do for you BT double fanatics
STF 262 AB (Iot Cas)
02h 29m 03.96s +67° 24' 08.7" P.A. 231.00 sep 3.0 mag 4.66,6.92 Sp A4V+F5V dist. 40.73 pc (132.86 l.y.)
Oh, I'm sorry. You thought 12 Lyn was incredible?
Wow, you have no idea! One of the most incredible system I've seen. Big beautiful primary surrounded by 3 gorgeous stars all with different colors. Seriously, made my night. SkySafari has a picture that honestly doesn't do it justice. I could see all the components much more easily than that. Awesome, simply awesome!
So, couple of nice solid doubles. Seriously cool systems. Let's try something that I haven't succeeded in before:
STF 774 AB (Alnitak - Zeta Orionis)
05h 40m 45.52s -01° 56' 33.3" P.A. 166.00 sep 2.4 mag 1.88,3.70 Sp +B0III dist. 225.73 pc (736.33 l.y.)
I think I saved the best for last. So cool! At 140x I could clearly separate two dots of bright light. However, here is where the telescope pulls away. At 300x two beautiful orbs right next to each other. My seeing NEVER supported splitting Alnitak before. I'm so stoked to see it!
Wow, what a fun night!
Yes, I also split Rigel (easy) and Sirius (less easy) and the Trapezium E and F just as a regular thing. Once you know what to look for these become second nature.
Fun fun fun night!
