OSC - R channel focusing priority?
7 replies to this topic
#1 Terata
Terata
Posted 22 October 2021 - 03:20 AM
I noticed something for the first time recently with an image of the Bubble nebula with ASI533mc OSC and Sharpstar 61EDPH using the Optolong L-eXtreme filter and the ZWO EAF for autofocusing. When I split the channels it appears that R is more out of focus when compared to G and B
I have seen some old threads about this but none of them really offer any kind of solution. Has anyone found a smart way of focusing with priority assigned to the R channel, the channel with the stronger signal for imaging emission nebula?
Br Alan
Integration Image with channel split, RGB in that order. 3 hrs integration time
Edited by Terata, 22 October 2021 - 03:25 AM.
#2 bulrichl
bulrichl
  • Loc: La Palma (Canary Islands)
Posted 22 October 2021 - 04:00 AM
Focusing according to the R channel will not fix the problem, then the G and B channel will be out of focus.
The specification of the ZWO ASI533MC says that the protect window in the camera is only an AR (anti-reflective) window. You will have to use a UV/IR cut filter additionally in order to cut off wavelengths > 700 nm.
Bernd
  • ks__observer likes this
#3 Terata
Terata
Posted 22 October 2021 - 09:12 AM
I am using the Optolong L extreme dual band filter so unless there is leakage of other wavelengths with the filter I would have thought that adding a UV IR cut would not make a difference.
Alan
#4 imtl
imtl
  • Loc: Down in a hole
Posted 22 October 2021 - 11:40 AM
This has nothing to do with uv-ir cut. It is about the CA of your optics and the fact that you use an OSC.
#5 bulrichl
bulrichl
Posted 23 October 2021 - 04:29 AM
Alan
Sorry, I missed the fact that you used a narrowband filter.
Bernd
#6 calypsob
calypsob
  • Loc: Virginia
Posted 28 October 2021 - 06:56 AM
Something is off here. Red should not be that blurry. Is this the doublet version of the 61?
#7 ks__observer
ks__observer
  • Loc: Long Island, New York
Posted 28 October 2021 - 02:16 PM
+1
#8 RogeZ
RogeZ
  • Loc: Palm Beach Gardens, FL
Posted 28 October 2021 - 07:59 PM
Yep. This is exactly what CA does.
