Adjusting the secondary in an Explore Scientific 12" dob
5 replies to this topic
#1 kurtfriedrich
kurtfriedrich
  • Loc: Washington, USA
Posted 22 October 2021 - 07:05 PM
Most Newtonians have 3 screws to adjust the secondary angle and if you move all 3, you can raise and lower the secondary in the primary path.
However the Explore Scientific dobs have the 3 screws perpendicular to the primary path, and while you can adjust the angle, you cannot move the mirror up and down.
The focuser is mounted into 4 holes which are slots, so you can loosen the screws and get some adjustment, but I need more.  Has anyone solved this problem?gallery_16287_17924_7921.jpg
#2 kurtfriedrich
kurtfriedrich
Posted 22 October 2021 - 07:10 PM
I might try adding washers and longer bolts to the truss attachment points to raise the secondary, see the green arrows.
Does that seem like a bad idea?
#3 Couder
Couder
  • Loc: Mansfield, Missouri in the Ozarks
Posted 22 October 2021 - 07:17 PM
Don't the vanes adjust?
#4 kurtfriedrich
kurtfriedrich
Posted 22 October 2021 - 07:19 PM
Only left and right to get it centered, not up and down.
thanks
#5 Jon Isaacs
Posted 22 October 2021 - 09:32 PM
That raises both the focuser and the secondary, that wouldn't help if you are trying to position the secondary relative to the focuser for collimation purposes.
#6 kurtfriedrich
kurtfriedrich
Posted 22 October 2021 - 09:51 PM
Dah!!
Guess I'll have to put in double then!!!!
thanks
