Daytime infrareds Jupiter and saturn
10 replies to this topic
#1 GSBass
GSBass
  • Loc: South Carolina
Posted 23 October 2021 - 06:05 PM
Daytime Infrared Jupiter and Saturn 630pm 642ir 10/23/21
  • KpS, aaube, happylimpet and 11 others like this
#2 GSBass
GSBass
Posted 23 October 2021 - 06:06 PM
Sat
  • Az Frank, KpS, happylimpet and 8 others like this
#3 petert913
petert913
  • Loc: Silverton, OR
Posted 23 October 2021 - 06:22 PM
Amazing !  How did you get the background so dark in daytime?
#4 Kiwi Paul
Kiwi Paul
  • Loc: Carterton, New Zealand
Posted 23 October 2021 - 06:40 PM
How interesting. Quite a good level of detail too.
Peter913 I would guess that the blue sky background would appear dark or black at infrared wavelengths. This leaves the camera recording IR wavelengths coming from the planets.
Cheers Paul
#5 GSBass
GSBass
Posted 23 October 2021 - 07:31 PM
That’s correct, sky is much darker in infrared, however it will still be grey instead of black but you can adjust it out easily by adjusting black and white levels in post processing, works best in early morning or late afternoon
#6 Aquat0ne
Aquat0ne
Posted 24 October 2021 - 02:53 AM
Great shots. I had no idea you can do daytime planetary photography like this. Can I ask what sort of camera you used? Is it had to find the target?
#7 GSBass
GSBass
Posted 24 October 2021 - 11:45 AM
Thanks, to do this well you need a zwo or qhy 462 or a playerone imx464 which is what I used here, all three cameras are highly sensitive to infrared, in addition you need infrared filter, I used a 642nm for these shots,
and yes it can be difficult to find them, if your lucky and the moon is out you can use it to sync on then slew to Jupiter… otherwise if it’s very late or early then if you can get in the vicinity of Jupiter it will show up in your finder…. So will Venus and Mercury as long as they are far enough away from sun.  You can not see Saturn but if you find Jupiter then you can hop to it easily.
lastly… one of the reasons I use the 642ir filter is it does allow some visible red through… so it’s useful to have it for centering the planets on chip using my flip mirror…. The more aggressive filters like the 850nm block all visible light so much more difficult to get on chip. Anyway it’s fun and works great on moon too
Edited by GSBass, 24 October 2021 - 11:46 AM.
  • Aquat0ne likes this
#8 CPellier
CPellier
Posted 24 October 2021 - 03:17 PM
Very nice work. The sky is darker in near IR but one problem is, Jupiter as well, is darker in near IR, so the expected contrast effect is rather weak. That's also why the BP642 will perform more than longer wavelength filters under such conditions, since the filter includes a part of visible red light, where the planet's albedo is higher.
#9 Aquat0ne
Aquat0ne
Posted 24 October 2021 - 03:28 PM
Thank you for the explanation. Truly great work.
  • GSBass likes this
#10 GSBass
GSBass
Posted 24 October 2021 - 04:32 PM
This certainly use to be true but tech marches on, Sony has created some very nice infrared chips that provide nice high contrast images in daylight, I’ve taken lunar photos that would rival my nighttime shots and although infrared on planets is a different animal altogether they tend to show pretty good detail… only thing is it’s not an all day thing, works best as sun is rising or setting…. And of course having good seeing is still required….. also obviously you have to like b&w
#11 GSBass
GSBass
Posted 24 October 2021 - 04:44 PM
Just ran that image through snapseed to bring out some detail… it’s a judgement call, I usually process most of my stuff with softer focus and contrast because I like them less noisy and natural…. Just didn’t want to give anyone impression it was because they were imaged in daylight…. Although detail is different in infrared, it still comes through just as much as color nighttime images…. It’s all in the post processing…. If you took a good image in the first place
  • Foc and Kiwi Paul like this
