Latest Losmandy g11g Guiding Performance?
Mount Imaging
4 replies to this topic
#1 wen_astroevo
wen_astroevo
  • Loc: Chicago/Boston
Posted 25 October 2021 - 02:10 PM
Hello,
Not trying to raise a lot of debates here, just wondering if someone could share their experience with the latest Losmandy g11g with guiding. I thought the new one piece worm gear and spring load eliminate the backlash (and other) potential issues, but I still find posts about the "76 second RA error" of g11g while searching around here and groups.io. Is this still a potential pain with the latest Losmandy mount? If so, will the Belleville washer alleviate the problem?
My goal is to take long exposure (5 minutes) images with 8'' SCT + 0.63x reducer with OAG + ASI174MM mini guiding. I guess severe 76 second RA error that can't be dealt with using PEMpro may be an issue at 1280mm focal length.
Thank you and clear skies!
Wen
#2 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 25 October 2021 - 02:21 PM
Have you posted here?
https://groups.io/g/...dy_users/topics
#3 SilverLitz
SilverLitz
  • Loc: Louisville, KY
Posted 25 October 2021 - 03:29 PM
Using PHD2 Multi-Star and OAG, my ES G11 (PMC-8) has guided ~0.4-0.5", and I have used exposures as long as 8 min.  Previously, using PHD2 single star and 60mm guidescope, 0.7" was my best, with 0.9-1.1" being typical.
The ES G11 (PMC-8) does not have the normal gear box, but instead is direct coupled to stepper motors.
#4 wen_astroevo
wen_astroevo
Posted 25 October 2021 - 10:11 PM
Hi Jim,
Thank you for your suggestion. I've looked through some groups.io posts regarding this, but have been quite confused by different opinions about the new g11g guiding performance. I might post the same question there as well.
Best,
Wen
#5 wen_astroevo
wen_astroevo
Posted 25 October 2021 - 10:13 PM
Hi Mark,
Thank you for sharing your experience! The guiding performance you have with multi-star sounds superior! I hope the spring load worm gear has similar performance.
Best,
Wen
Also tagged with one or more of these keywords: Mount, Imaging
