Rings on Mirror's Surface
Mirror Making
6 replies to this topic
#1 iTesla
iTesla
Posted 25 October 2021 - 06:33 PM
Hi all,
You helped me with an eight inch ƒ8 mirror recently, thanks again for your help. It should be aluminized soon (60 days).
I'm attempting to figure a ten inch ƒ4.5 mirror to see if I can do it on my own. In trying to correct a TDE and ignoring the mirror sticking and releasing, I pushed through. I was thinking a little roughness in exchange for a good edge was acceptable. Perhaps not.
Are these rings a result from poor contact or are the facets too small and they are the culprit? Or both? OR something else?
What size should the facets be?
#2 Pinbout
Pinbout
Posted 25 October 2021 - 07:59 PM
The facets on the lap need to be off center, both directions
Edited by Pinbout, 25 October 2021 - 07:59 PM.
  • PrestonE likes this
#3 iTesla
iTesla
Posted 25 October 2021 - 10:03 PM
So my crosshair lines intersect close to the center of a facet, but they should meet at the red dot. Originally they did meet off center, but after trimming they shifted towards the center. I failed to recheck.
I'll have to remake the lap. Is a 1.5 inch square facet too big?
#4 mark cowan
mark cowan
    Vendor (Veritas Optics)
  • Loc: salem, OR
Posted 25 October 2021 - 11:57 PM
No the size is not a problem, the symmetry is though.  Also vary up the strokes by small amounts randomly (or as close as you can come) because the rings are the result of the same facets (and their symmetrical partners) hitting the same spots on the mirror, along with the channels, leading to over/under polishing resulting in the rings.
If you facet like this:
the problem will not appear as there is very little possible symmetry no matter how the strokes go...
  • darksky4us likes this
#5 Pinbout
Pinbout
Posted 26 October 2021 - 09:10 AM
uhmmm.... I put your pic into illustrator, drew a circle around your lap and the green do is the center of the circle.... how did you locate your red dot?
you need to be more off center than actually being right on center... ha ha ha
#6 Pinbout
Pinbout
Posted 26 October 2021 - 09:16 AM
but alos press netting into your lap... I use the stuff the supermarkets pack fruit in.
https://www.youtube....1Mi3FfQo0&t=23s
also you can do figure 8 strokes to get rid of all the rings
https://www.youtube....jPcDoB&index=12
also about the channels
https://www.youtube....h?v=T03b-5LyWGk
Edited by Pinbout, 26 October 2021 - 09:18 AM.
#7 iTesla
iTesla
Posted 26 October 2021 - 12:10 PM
That was just an illustration where the center dot should be located on a central facet. If you could slide all the pitch so the red dot was moved to the green dot, the lap would be OK or better.
Also tagged with one or more of these keywords: Mirror Making
