152 mm triplet refractor
5 replies to this topic
#1 Cascade Alpacas
Cascade Alpacas
  • Loc: Hood River, OR
Posted 26 October 2021 - 11:53 AM
I have a 152 mm achromat, can you replace  the lens with a triplet lens?
#2 fftulip
fftulip
Posted 26 October 2021 - 12:18 PM
Yes you can replace an achromat objective with a triplet.  It's easiest to do if the lens cells are the same diameter.  When I replaced my achromat with a triplet I needed shim the new cell to fit the tube - not recommended if you don't have mechanical skills.  Also the focal length should be nearly the same, otherwise you may need to shorten or lengthen the light path, also possibly modify any baffles.  Of course after the change, you will have to collimate everything.  So while it's possible it's not an easy task.
  • petert913 likes this
#3 Cascade Alpacas
Cascade Alpacas
Posted 26 October 2021 - 06:11 PM
Thanks. I'm a machinist and  I work with carbon fiber and molds. This should not be to hard. Would you know where I could find a 152 mm triplet lens? Thanks
#4 Steve Cox
Steve Cox
Posted 26 October 2021 - 06:55 PM
I was going to recommend istar-optical.com, but I just looked, and the only triplet lenses they sell now are 140mm and 170mm, and both are at a price point you'd be better off just buying a whole new scope.
#5 ris242
ris242
  • Loc: Wellington, New Zealand
Posted 26 October 2021 - 07:14 PM
APM Germany - 152mm f/7.9
9.91 lbs
  • drd715 likes this
#6 Westseen
Westseen
  • Loc: CA
Posted 30 October 2021 - 11:10 AM
9.91 lbs
The APM 152 doublet is f/7.9 & 2.5 kg or 5.5 lbs.  So if the weight seems too much...
It would be nice if we could buy a ~150mm oil spaced triplet.  That would be much lighter.
User ThomasM meantions here:
https://www.cloudyni...telescope-r3059
160mm, triplet, oil spaced, f/6.5, weight = 3.5 kg (7.7 lbs)      ... just ctrl f "3,5"
I asked CFF if they were willing to sell just the lens, but Catalin said no at this time.
Edited by Westseen, 30 October 2021 - 11:12 AM.
