Deep Cycle Power Solution (premade)?
10 replies to this topic
#1 Naptown Larry
Naptown Larry
Posted 26 October 2021 - 12:03 PM
Does anyone make a premade battery case with cigarette lighter, USB, and 12vdc barrel connectors that you can just drop the deep cycle battery of your choice into for remote site power? Or is DIY the only option?
#2 starrycanuck
starrycanuck
  • Loc: Toronto, Canada
Posted 26 October 2021 - 12:06 PM
Powerwerx may have some of interest https://powerwerx.co...eries-chargers¬†
  • Raginar likes this
#3 astrohamp
astrohamp
  • Loc: Massachusetts
Posted 26 October 2021 - 01:20 PM
Battery box?   Although some DIY may be in order.
#4 Raginar
Raginar
  • Loc: Pensacola, FL
Posted 26 October 2021 - 03:12 PM
I've got one.  It's awesome.
#5 Naptown Larry
Naptown Larry
Posted 27 October 2021 - 08:25 AM
Here's one on Amazon with 1 USB, 1 cigarette lighter input, and a power meter that's intended for a trolling motor. Would this be safe to run a mount and cameras? Or does the power need to be further regulated?
Newport Vessels Trolling Motor Smart Battery Box Power Center with USB and DC Ports, Black, Medium https://www.amazon.c...ding=UTF8&psc=1
#6 jdupton
jdupton
  • Loc: Central Texas, USA
Posted 27 October 2021 - 09:52 AM
Larry,
   A Google search led me to a nice non-DIY box sold by HardKorr in Australia. A second search turned up the same unit with a different brand on Amazon. You would need to check the physical dimensions to make sure it will hold any battery you wish to put into it.
https://www.amazon.com/Li-Power-Multi-Function-high-Capacity-Heavy-Duty/dp/B07W5HJ5LV
   This has just about everything I would want or need. It has 12v cigarette outlets, PowerPole connections, USB power outputs, a master On/Off safety switch, multifunction display, and more. More searching could probably turn up similar units with different brand names.
   I went the DIY route for the same features but if this one had fit my battery, I could have used it. The cost ended up being similar.
John
#7 Naptown Larry
Naptown Larry
Posted 29 October 2021 - 05:05 PM
John, thanks for the tip! That one looks like it's definitely better suited for an Astro rig.
#8 Psychlist1972
Psychlist1972
  • Loc: Maryland, USA
Posted 29 October 2021 - 05:11 PM
What's the advantage of something like this vs. the dedicated lifepo-based solutions? Is it primarily cost?
Pete
#9 Naptown Larry
Naptown Larry
Posted 29 October 2021 - 06:35 PM
Cost, simplicity, and being able to choose the size battery you want.
#10 rhaskins
rhaskins
  • Loc: Minnesota
Posted 30 October 2021 - 08:45 AM
I use one of these:
http://www.westmount...ducts_id=dctogo
everything that I attach, including those cigarette plugs, have Anderson Power Poles on them. All my scope and accessory power is Power Poles including my laptop - bought the 12 volt charger for it also.
I use a big 100 ah AGM but am pondering a LiFePO4 for the weight thingie.
Rick
  • Naptown Larry likes this
#11 rhaskins
rhaskins
  • Loc: Minnesota
Posted 02 November 2021 - 04:24 PM
Larry:
https://www.amazon.c...T58C,B08P6LP1J9
And you can use them for your trolling motor!
Rick
