Shimmy/Jiggle in CEM40 Normal?
7 replies to this topic
#1 rcamikes
rcamikes
  • Loc: Northern KY, USA
Posted 27 October 2021 - 06:42 AM
My fully loaded mount was blown over. I tightened the RA belt and there is no play in the belt. I cannot remember if the mount had slack/jiggle or idk what before it fell over. I think it did but idk. I am attaching link to a video of the small shimmy the mount has when you jiggle with your hand. I know my HDX 110 does not do this. Any feedback would be appreciated!
https://1drv.ms/v/s!...HkdLxsPDvhfAyAA
Edited by rcamikes, 27 October 2021 - 12:45 PM.
#2 sc285
sc285
  • Loc: Northeastern KS
Posted 27 October 2021 - 09:02 AM
Here is a file which addresses this issue.
Attached File  CEM40_GEM45_PlayFixing_1_.pdf   340.1KB   39 downloads
#3 rcamikes
rcamikes
Posted 27 October 2021 - 12:04 PM
Thanks for that. As I went through the process, I discovered the RA worm has a slight lateral movement. Obviously anything more than 0 is an issue. Any ideas how to “tighten” that up?
#4 rcamikes
rcamikes
Posted 27 October 2021 - 12:45 PM
Do you have the CEM40 RA Worm Replacement pdf?  I am sure that's what I need.  Thx!
#5 sc285
sc285
Posted 27 October 2021 - 02:08 PM
No. Only had the one on adjusting the play and belt tensioning.
Don't know if there is one for worm replacement. Might check with iOptron.
Rob
#6 leedpeterson
leedpeterson
Posted 20 November 2021 - 04:56 PM
Hi Everyone,
I have significant freeplay in a brand new CEM40EC in the Dec axis not RA. Does anyone have success getting these procedures to remove freeplay in the Dec? The instructions have a number of disassembly steps for the RA that seem excessive for Dec.
I've also contacted iOptron.
Edited by leedpeterson, 20 November 2021 - 04:56 PM.
#7 rcamikes
rcamikes
Posted 20 November 2021 - 05:10 PM
I’m guessing it’s loose end caps on the worm gear.
#8 Kevin_A
Kevin_A
  • Loc: Belmont, Ontario Canada
Posted 20 November 2021 - 06:51 PM
Brass endcap at end of worm… loosen its setscrew, turn inwards the endcap until tight, back it of 1/16 of a turn and tighten setscrew… done.
