"Breaking in" a mount
8 replies to this topic
#1 nyx
nyx
  • Loc: Germany
Posted 27 October 2021 - 07:40 AM
Many people believe that you have to play X hours through a new guitar amplifier in order to make it sound more mellow/balanced and less harsh, otherwise known as "breaking in the speaker".
It made me wonder, is there such a thing when it comes to astronomy mounts (including star trackers)?
Would letting a new mount (or a mount that has been sitting idle for a while) run for X hours with no or little load improve its performance in terms of tracking etc.? You know, mixing/softening up the grease, removing any manufacturing spurs and edges via friction, warming up the gears so to say.
  • teashea likes this
#2 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 27 October 2021 - 07:44 AM
I remember reading of a user who ran his new mount's RA continuously for 24 hours, with fine grinding paste instead of grease.
To improve the worm to wormwheel mesh.
#3 zakry3323
zakry3323
  • Loc: Fairfield, Westmoreland County, PA
Posted 27 October 2021 - 08:28 AM
I suppose it might depend on the mount a bit. I've seen improvement in say, an AVX mount when the gears have been cleaned, hand-polished and relubed. This is sometimes part of the service provided by companies that "supercharge" mounts. I haven't seen anything in a modern mount that necessitates chamfering or grinding down sharp edges. The mass produced gear trains are still precision ground- I wouldn't touch a worm gear personally, other than to clean or re-lube it. Older mounts, I don't have as much experience with, but I guess if they're used they're broken in already aren't they :)
#4 EJN
EJN
  • Loc: Between eigenstates
Posted 27 October 2021 - 09:48 AM
Mounts are not car engines.
  • David-LR, zakry3323 and teashea like this
#5 David-LR
David-LR
  • Loc: Indio, CA
Posted 27 October 2021 - 10:06 AM
I never did anything but use my mount.  If it has problems with tracking quality, you would have to address that, but otherwise, it should be ready to go.
#6 teashea
teashea
  • Loc: Lincoln, Nebraska, USA
Posted 27 October 2021 - 08:08 PM
These are the same people who believe that you have to break in speakers, that gold speaker wire will sound superior to copper, etc etc.  There have never been a valid double blind experiment demonstrating these things.
Mechanical things like mounts may be different.
  • t-ara-fan likes this
#7 CMS1288
CMS1288
  • Loc: Sarasota, Fl
Posted 28 October 2021 - 08:18 AM
As a guitarist yes, speakers need some sort of break-in to relax the fibers in the cone.
A mount however, I’m reluctant to think it endures enough stresses to cause beak-in. It’s not like a car chassis or motor mounts that are subject to lots of vibrations and resonance frequencies.
#8 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 28 October 2021 - 12:50 PM
Many people believe that you have to play X hours through a new guitar amplifier in order to make it sound more mellow/balanced  .
Glad you mentioned that.  I have* upgraded my AC power receptacles  to Furutech receptacles. For both the mount power supply and my laptop.
https://www.thecable...receptacle.html
They are amazing. Guiding improved by 15% the first night, and after a week it is 50% better.  And clouds are reduce by 8%-11% consistently. A bargain at USD255 per unit.
How does it work?
Nano Crystal² Formula --- NCF is comprised of a special crystalline material that has two “active” properties. First, it generates negative ions that eliminate static and secondly, it converts thermal energy into far-infrared. Furutech then combines this remarkable crystalline material with nano-sized ceramic particles and carbon powder for their additional “Piezo Effect” damping properties. The resulting Nano Crystal² Formula is the ultimate electrical and mechanical damping material – only found in Furutech products!
* actually I didn't LOL.
Edited by t-ara-fan, 28 October 2021 - 12:50 PM.
  • SkipW likes this
#9 SkipW
SkipW
  • Loc: Oklahoma, USA
Posted 28 October 2021 - 06:28 PM
How does it work?
This sort of review is the reason I drifted away from audio forums. Some of the (very!) high-dollar, ludicrously fat and heavy power cables weren't even UL listed.
To answer the OP's question, just use it. If you find performance issues that cause you problems, address them.
