Efficiently using LRGB exposure time?
4 replies to this topic
#1 TodRiley
TodRiley
Posted 27 October 2021 - 11:17 PM
I want to use my exposure time more efficiently owing to limited cloud free nights.  The common practice seems to be expose L for 50%, and RGB equally for the reminder.  Given that RGB exposures only provide color information and that L is the most important for resolution, what is the minimum ratio of RGB to L?   Knowing this will  allow me to maximize the time imaging with the L filter.   Thanks in advance.
#2 ks__observer
ks__observer
  • Loc: Long Island, New York
Posted 27 October 2021 - 11:51 PM
Experiment.
I saw one very experienced imager ssy you can reduce RGB quite a bit.
You should also be using your RGB data to creat a synthetic lum with the L data.
Edited by ks__observer, 27 October 2021 - 11:51 PM.
#3 bobzeq25
bobzeq25
Posted 28 October 2021 - 02:20 AM
Common practice is pretty near ideal.  As is often the case.  "The wisdom of crowds" applies.
I suggest you read this before cutting back "too much" on the color data.  This is a very expert imager.
https://astroimages....good-color.html
  • licho52 likes this
#4 fate187
fate187
  • Loc: Germany
Posted 28 October 2021 - 04:10 AM
From my experience it is better to expose RGB the more the better, if you live in light polluted environment. Otherwise blotchiness and/or uneven background with very difficult color gradients are the result.
#5 Rasfahan
Rasfahan
  • Loc: Hessen, Germany
Posted 28 October 2021 - 09:26 AM
Yes, in Bortle 4, 50%L and 50% RGB (combined) worked very well. In Bortle 6 I need better color data, so I‘ve started to expose each channel for the same time. Skipping L, I find I get „too much“ color - i. e. while saturation can be pushed a lot, stretching reveals more noise. The brighter the object, the less RGB I need, as a rule.
