Documentation for Cartes du Ciel (Sky Charts) on Linux Mint?
Charts Equipment
4 replies to this topic
#1 Xeroid
Xeroid
  • Loc: USA
Posted 18 November 2021 - 11:14 PM
Greetings,
Well its been raining here for two days so I though I would test my sanity by installing Cartes du Ciel (Sky Charts) on my Linux Mint 20.2 PC.
Well, I have been unable to find any human readable documentation on how to install, CONFIG & run it.
Just trying to see if I can control my AZ Mount Pro via Wifi using Linux Mint.
Must be my old age but the entire process sure does not seem to be very "intuitive".
I would appreciate your suggestions, links to install/configuring/running documentation for Cartes du Ciel on Linux Mint.
#2 ziggeman
ziggeman
Posted 19 November 2021 - 02:19 AM
I'm usually a windows user but I have tried Ubunto linux ages ago. Maybe these links could help you.
https://www.ap-i.net...art/en/download
And for ubunto : https://askubuntu.co...u-ciel-skychart
good luck
#3 Xeroid
Xeroid
  • Loc: USA
Posted 19 November 2021 - 09:49 AM
  • ziggeman likes this
#4 lambermo
lambermo
  • Loc: .nl
Posted 19 November 2021 - 10:15 AM
I tried skychart on linux recently and did not run into problems connecting to my gear. Maybe just show us where you are stuck ?
#5 Xeroid
Xeroid
  • Loc: USA
Posted 19 November 2021 - 11:57 AM
GOT IT!
Read the docs over several times and got it working by shear luck.
My Hiccups:
1. Could not find how to start "Cartes du Ciel"
    - After rebooting, found a new menu item named "Skychart"...doh!
2. Failed to connect to INDI server
    - Going over the docs found once again I saw a Terminal command: indiserver indi_lx200gps
    - OK, where is my mount driver?
    - Found that sneaky directory using "find" command
3. Did not know which Indi driver to use for my AZ Mount Pro
   - Finally saw a new menu item named: "INDIstarter"
   - Hit SETUP and GUESSED IOptron CEM60 since there was no AZ Mount Pro listing.
Started server then started SKYCHART and was able to connect & control my AZ Mount Pro,
"Oh, that was so easy even a ..... could do it"
NOT!
HOWEVER, the one positive note was I ran Linux Stellarium 21.2 and there in the telescope config was an INDI selection!
Who knew?
NOW with the INDI server running & the CEM60 driver selected, hit that button and connected to my AZ Mount Pro and visible target.
Bottom line:
Given the many variants of Linux, no wonder the installation process stinks. bangbang.gif
Edited by Xeroid, 19 November 2021 - 12:18 PM.
  • Steve Cox and ziggeman like this
Also tagged with one or more of these keywords: Charts, Equipment
