Many years ago at the RIverside Telescope maker's meet in So Cal I ran into an older gentleman who was displaying some small fast newtonians that he had made by warping commercial spherical mirrors into a parabolic shape. This was probably in the early 1990s.
Does this sound familiar to anyone?
IIRC he epoxied a single hex head bolt to the back center of an aluminized, spherical 5 inch mirror. The mirror was supported mostly by the edges with a ring of carpet. The bolt protruded through the middle of a plywood 'cell' and was held in place with a washer and a wingnut.
He stated that applying tension on the central bolt would warp the mirror into a paraboloid.
Now, I can't recall anything else about this. Getting old sucks.
Apparently it's fairly cost effective commercially to make a smooth spherical mirror, but parabolizing -not so much.
I was looking at my junk box, which included an f/8 spherical 114mm primary from a cheap Cometron reflector which needed recoating. I was thinking about making a pitch lap and parabolizing this thing before sending off for aluminizing when I remembered this mirror warping thing.
Now, it may not make that much difference with a small f/8 reflector, since my Celestron C4.5 apparently also has a spherical primary and it works reasonably well. But what about those cheap 5 inch short tube Jones-Bird scopes that have a 'corrector' in the focuser drawtube? They use a fast spherical primary and are common and cheap secondhand since they suck so badly. Maybe they would be a good candidate for mirror warping??
Has anyone heard of this and tried it?
