First Post: Nov-20-2021 Quark full disk and higher power
Solar Imaging
17 replies to this topic
#1 0ak3
0ak3
Posted 25 November 2021 - 03:37 PM
Hi All,
Long time lurker, first time poster. I just wanted to share my first set of mostly-decent images with my new quark as well as my thanks to all the active posters on this forum who have provided me with so much information about solar observing and imaging. Constructive criticism welcome. If I can figure out how to link to higher-quality images, I will do that.
1. The full disk is a single frame with an ST80 stopped down to 60 mm, 0.5x focal reducer. The camera is an HIK vision MV-CA050-20UM (onsemi Python 5000 chip 2592x2048 4.8 um pixels).
2. Higher power image is from an AT102ED, full aperture with 0.5x focal reducer and a 1200 x 1200 ROI in the same camera.
Aligned in AS!3 and post-processed in IMPPG.
Best,
Derek
  • BYoesle, Sky Captain, peterm and 12 others like this
#2 newlife
newlife
Posted 25 November 2021 - 04:16 PM
Great images!!
#3 IR656nm
IR656nm
Posted 25 November 2021 - 05:26 PM
Your full disc looks ok. How did you get a full disc on a 80mm telescope with a Quark?
I thought that was not possible.
Your higher detail 2nd image looks slightly over processed. Remember, the sun is made of gas! and should naturally be softer. Just my opinion, thats all.
Magnus
#4 MalVeauX
MalVeauX
  • Loc: Florida
Posted 25 November 2021 - 08:32 PM
Lovely captures Derek, good job getting that disc out of a Quark setup.
Very best,
#5 rigel123
rigel123
  • Loc: SW Ohio
Posted 25 November 2021 - 08:49 PM
Great shots Derek, welcome!
#6 0ak3
0ak3
Posted 25 November 2021 - 09:34 PM
Thanks! Happy to have something to contribute. The full disk just passes in the ST80 (400mm focal length) and then just fits on the sensor after the focal reducer. I had also not seen many full disk quark images before so was sort of surprised that it actually worked out. (Calculated before getting this particular camera).
  • Siderius likes this
#7 peterm
peterm
  • Loc: Gold Coast, Queensland, Australia
Posted 26 November 2021 - 06:30 PM
I like these Derek, well done.
#8 IR656nm
IR656nm
Posted 27 November 2021 - 03:37 AM
Hi Derek,
Well done on you first solar full disc, thats good work and nice looking image.
I was wondering if you could share your focal reducer details, as I have great problems with focusing if I apply a focal reducer.
I have the Svbony 0.5x focal reducer and also Datyson 0.5x focal reducer (1.25 inch mounted which screws onto the camera nose piece). I have tried another CS-mount version with different spacing. Still hit and miss to focus.
What is your focal reducer solution - which focal reducer and how do you put it in your imaging train ? Using spacers to get the correct distance between FR and camera sensor ?
Thank you.
Magnus
#9 0ak3
0ak3
Posted 27 November 2021 - 12:21 PM
Hi Magnus,
I have not had problems reaching focus with the 0.5x focal reducer, but I have only used it after the quark, which has a built in 4.2x amplifier. I am using a 3cm extension after the focal reducer which puts me at about 4cm to the sensor. I believe this particular GSO focal reducer is intended to be used with a 51.5mm spacing, but I did not have that length of extension tube lying around (https://agenaastro.c...cers-guide.html). Per the linked article, this probably puts me at 0.65x. It works, but I will probably play with different spacings in the figure.
For the full disk I am using:
ST80 stopped down to 60mm to reach f6.7 (x4.2 for f/28 at the etalon)
--> 1.25inch Badder UV/IR filter
--> SVBONY dielectric diagonal (1.25 inch)
--> Quark Chromosphere (built in 4.2x telecentric amplifier)
--> GSO 0.5x focal reducer (1.25 inch SKU: OFR-GS-GSRD)
--> 3cm 1.25 inch extension to C-mount (SVBONY "C Mount to 1.25" Video Camera Barrel Adapter" ASIN: B07HRK3KBH, also came with a UV/IR filter)
--> HIKVISION camera
For the higher power I am using
AT102ED at full aperture (f/29.4 at the etalon)
--> Badder H-alpha 35nm filter as ERF
--> Astrotech 2-inch dielectric diagonal
Hope this is helpful.
Best,
Derek
  • BYoesle and IR656nm like this
#10 BYoesle
BYoesle
  • Loc: Washington USA
Posted 27 November 2021 - 02:22 PM
Derek, thanks for not colorizing or using a negative disc image - they generally make image evaluation difficult.
These are very good first images. However, rather than being over-processed, they instead both are noticeably off-band, with a predominance of dark mottles (aka spicules) that are +/- 0.5 A off the 6562.8 A line.
One of the downsides of the Quark filters is that they vary greatly as to a set temperature and the actual center wavelength (CWL), and you have to "guess" what the correct temperature dial setting is. This is particularly difficult for those new to H-alpha where on versus off-band image subtleties are difficult to differentiate.
Below on the left is Derek's close-up with the 102ED telescope and Quark filter image, on the right is an on-band image made with a pair of Tucson SM90 etalons with an ED100/900 telescope at roughly the same image scale.
Click for larger.
Just seeing prominences and filaments is not accurate enough to determine if you are on-band, and learning to judge by the actual observation of active regions, including fibriles, plage, and other subtle chromospheric network features of the disc is IMHO essential.
Note that double stacking* eliminates the need for separate disc and prominence exposures, or the use of a negative disc image to blend the two.
*Properly exposed single stack images with a uniform contrast gradient can actually produce similar results if processed well.
Edited by BYoesle, 27 November 2021 - 03:35 PM.
  • AllanDystrup and LFORLEESEE like this
#11 0ak3
0ak3
Posted 27 November 2021 - 04:32 PM
Thanks Bob,
This is exactly the sort of feedback I was hoping for. Black and white images are also better for looking at and processing fluorescence microscopy images, which I do at times for my day-job.
So your assessment is that I am ~0.5A off in my tuning? What I see on your image compared to mine is that the spicules are somewhat elongated and show less variation in intensity from one "cluster" to the other. The lighter areas between clusters of spicules also contain more information in yours.
In the above images, I am +2 clicks clockwise on the quark because, visually, that seemed to produce the most contrast. This should be 0.2A blue shifted. I was likely looking at spicules when tuning so hopefully just my misjudgment about what is on-band. I plan to do a series of images to test tuning, but have a very unreliable clock drive on my CG4 and thought that would be too big a source of variation to do meaningful comparisons. I will try some visual observing to sort it out.
If one goes further off-band, what happens? How large is the range where the spicules are prominent?
BTW, I do have the Solar Astronomy book on which you are an editor and it is a truly fantastic resource.
Best,
Derek
#12 BYoesle
BYoesle
Posted 28 November 2021 - 12:17 AM
Hi Derek,
As you go father off band you admit more light from the photosphere and lose chromosphere details and prominences. The mottles (or rosette structures) are most prominent when seen off-band to the red and blue wings of the H alpha line (Doppler shifted in the image below). On-band they are usually obscured in the "general chromosphere." In some ways they are like prominences in that they appear darker against the disc, and bright when seen against the background of space.
  • GUS.K, Siderius and LFORLEESEE like this
#13 0ak3
0ak3
Posted 28 November 2021 - 02:58 PM
Thanks. This is very helpful.
#14 IR656nm
IR656nm
Posted 01 December 2021 - 05:42 AM
Hi Magnus,
Best,
Derek
Thank you so much Derek,
I will copy those details and see if I can adjust or apply them to my setup.
Magnus
#15 IR656nm
IR656nm
Posted 01 December 2021 - 06:06 AM
Hi Magnus,
Best,
Derek
Dear Derek,
I think I was trying this setup before. I think I could not get my ASI120mm-S camera to reduce using this type of setup (0.5 focal reducer attached to end of standard camera 1.5 inch nosepiece.
I think I got a reasonable image with an ASI174mm-S but found the normal non-reduced image satisfactory anyway.
I will have to test it again when the sun gets higher. I am forgetting what I did and did not do !
Magnus.
#16 0ak3
0ak3
Posted 01 December 2021 - 10:04 AM
I don't think the 174mm will fit a full disk with this setup. The chip I used is bigger so I was able to get it in one frame. See image below using a 2x Barlow. It should be 2.1 (4.2x0.5) but that is not an option in the fov calculator that I used. The "custom camera" is the hikvision, yours are labeled.
https://astronomy.to.../field_of_view/
  • IR656nm likes this
#17 IR656nm
IR656nm
Posted 01 December 2021 - 10:09 AM
Hi Derek,
Thanks for this advice. I see your HIkvision camera has a bigger sensor than the ASI 174mm. I was not really looking for a FOV to cover the full disc. I can reasonably do a mosaic from a few panels. I once did a 18 panel merge from a ASI 120mm-S camera (from a 70mm ED70 refractor F6 scope with a Quark. 18 panels. Needed a lot of work. However, I did not a full process of it by stacking all the videos. I just used SER player to extract a single reasonable image from the video files, and stacked 18 panels....
I was having problems with getting a sharp/well exposed or focused image with a 0.5x focal reducer..
Magnus
#18 IR656nm
IR656nm
Posted Today, 08:00 AM
Click for larger.
Hello Bob,
I was wondering why your image on the right hand side has so much detail compared to a typical one from Gong.nso.edu ? Is it because the NSO are imaging at lower resolution or something else which I am not aware of ? See the typical images from Gong.nso.edu today. There is no sign of those magnetic field curves fibril like structures which are visible in the finely imaged part of the sun in the right hand side image.
Thanks for looking,
Magnus
Also tagged with one or more of these keywords: Solar, Imaging
