The Pleiades (M45) - Bortle 1
26 replies to this topic
#1 Spastroof
Spastroof
  • Loc: Riyadh, Saudi Arabia
Posted 28 November 2021 - 05:32 AM
My Pleiades (M45) shot with the surrounding dusts 🌟
Equipment:
- ASI533MC Pro (Temp at -10C)
- Rokinon 135mm @ F/2.8
- iOptron GEM28 Mount
- ASI120MM Mini Guide Camera
- ZWO Mini Guide-Scope
- ASIair Pro
- Astronomik L3 Filter 2"
- ZWO EAF
Frames:
- Lights: 182 X 120" (6 hours)
- Dark: 50
- Flat: 30
- Dark Flat: 30
- Bortle 1-2
Post-Processing:
PI, PS
Astrobin:
https://www.astrobin.com/lkzuck/
Twitter:
https://twitter.com/...PqGhnUiSFw&s=19
Instagram:
https://www.instagra...edium=copy_link
M45
  • Dagobert, Acer, Mert and 40 others like this
#2 Mert
Mert
  • Loc: Spain, Pamplona
Posted 28 November 2021 - 05:53 AM
Amazing amount of dust, spectacular!
  • Spastroof likes this
#3 j.gardavsky
j.gardavsky
  • Loc: Germany
Posted 28 November 2021 - 06:26 AM
Amazing wide field with the molecular clouds around and inside the Pleiades!
Thank you so much for sharing,
JG
#4 Tapio
Tapio
  • Loc: Tampere, Finland
Posted 28 November 2021 - 07:06 AM
Amazing Pleiades surrounded by IFN.
One observation - looking at histogram in AB is it too blue, more red?
#5 matt_astro_tx
matt_astro_tx
  • Loc: Dallas, Texas
Posted 28 November 2021 - 07:29 AM
Wow.
#6 airscottdenning
airscottdenning
  • Loc: Colorado
Posted 28 November 2021 - 08:11 AM
Spectacular!
#7 imtl
imtl
  • Loc: Down in a hole
Posted 28 November 2021 - 08:13 AM
Incredible. Bortle 1 is the best lp filter.
Why add the diffraction spikes I have no idea...
  • mikemarotta and Spastroof like this
#8 Knasal
Knasal
  • Loc: Wisconsin, USA
Posted 28 November 2021 - 09:24 AM
Wow.
+1 ! That was my reaction!
Kevin
#9 mikemarotta
mikemarotta
  • Loc: Austin, Texas
Posted 28 November 2021 - 09:46 AM
- Bortle 1-2
Post-Processing:
Wow. Astrophotography gets cloying, like white sugar sprinkled on honey, but that picture is truly both a work of art and scientifically interesting.
Thanks for sharing!
Best Regards,
Mike M.
#10 unimatrix0
unimatrix0
Posted 28 November 2021 - 10:05 AM
Isn't that the photo lens shutter (Rokinon 135mm) causing that effect?  It's an F2 lens and he closed it to F2.8 which is recommended.
  • DRK73, imtl and Spastroof like this
#11 Spastroof
Spastroof
Posted 28 November 2021 - 10:17 AM
Thank you all for your kind words!
When I finished the processing I felt the image was kind of gray and I thought a little more blue + saturation will give it a good taste!
Because of Lens' shutter. I like the spikes though :)
Thanks for sharing!
Best Regards,
Mike M.
Thank you for your kind words!
Exactly!
  • DRK73 likes this
#12 m2434
m2434
  • Loc: Central Massachusetts
Posted 28 November 2021 - 10:23 AM
Wow one of the most detailed I’ve seen of the region. You think you’ve seen it all, and then you see something better. Even with modest equipment, by modern standards, the bottle 1 shows how good this stuff, and our processing tech is getting.
#13 imtl
imtl
Posted 28 November 2021 - 10:26 AM
Thanks for the clarification! I agree I think it needs a bigger step down to avoid the diffraction spikes. Never used one of these.
#14 cmas
cmas
  • Loc: Finland
Posted 28 November 2021 - 10:33 AM
I don't like the spikes (personal preference), but boy do I like the image! Great job, this is truly an excellent photo! Awesome!
#15 MHamburg
MHamburg
  • Loc: Brooklyn, NY/Berkshires, MA
Posted 28 November 2021 - 11:18 AM
Awesome image!!
Michael
#16 Lead_Weight
Lead_Weight
  • Loc: Houston
Posted 28 November 2021 - 11:30 AM
The lens has no shutter. It's from the aperture blades which you can adjust more open or more closed. There's one spike per blade groove. Some lenses can have more or less blades and the number of spikes is equal to how many and how well defined the blades grooves are. Adjusting the aperture can slow down or speed up the F value, but also increase or decrease the spikes.
#17 Spastroof
Spastroof
Posted 28 November 2021 - 11:37 AM
Great info!
Actually what I meant were the blades but I didn't know what it called in English "I'm an Arabic speaker" so I thought it called the shutter
  • imtl and Lead_Weight like this
#18 nfotis
nfotis
  • Loc: Athens, Greece
Posted 29 November 2021 - 10:50 PM
Very nice image.
If you want to avoid the spikes from the blades, you can use step-down rings instead of the blades.
These are very cheap (these are plastic, after all), and perfectly circular.
You could for example use a step down ring 77mm to 67mm, or even 77-62
N.F.
#19 ziywang50
ziywang50
Posted 29 November 2021 - 10:57 PM
Best Pleiades image I have seen
#20 Spastroof
Spastroof
Posted 30 November 2021 - 01:01 AM
Very nice image.
N.F.
Thanks for the info!
Thank you so much
#21 Spastroof
Spastroof
Posted 30 November 2021 - 06:53 PM
My shot is moving now 😁💎 I hope you like it.
I used After Effect if you're interested 💙
YouCut 20211201 004331610
  • Pingu and matt_astro_tx like this
#22 matt_astro_tx
matt_astro_tx
Posted 01 December 2021 - 04:55 AM
That's very cool. Nice job on the animation.
#23 Tayson82
Tayson82
  • Loc: Poland / Wolomin
Posted 01 December 2021 - 05:45 AM
Nice image, but I think to much agresive processing distroy finally soft nebula effect.
#24 Spastroof
Spastroof
Posted 01 December 2021 - 05:54 AM
Actually this is my softer version, below is my 1st version, more aggressive. Even though APOD shared the below one on their Instagram story, but I like the softer version more :)
M45 1st
#25 bjkaras
bjkaras
  • Loc: Back and forth between Santa Clara, CA and Las Vegas, NV
Posted 01 December 2021 - 06:29 AM
The first time I ever saw the Pleiades from a Bortle 1 site it blew me away. At first I thought my eyepiece was either dirty or just fogged up, but I was seeing the reflection nebulosity directly and it was so bright I couldn’t believe it.
