Super-Simple Servomotor Controller
DIY Visual
4 replies to this topic
#1 rlw1138
rlw1138
  • Loc: 88W 42N
Posted 28 November 2021 - 08:51 PM
I don't "astro-photo" -- strictly visual -- and I wanted a way to turn my focuser knobs without touching them.
I didn't need it to remember any focus positions, or compensate for temperature, or to interface with k-stars or stellarium or whatever.
I just wanted it to "feel" just like using the normal focuser knob.
I also wanted an easy Arduino project.
I wanted it all to be fairly cheap, too.
I've come up with a very workable combo: the software's only a little over 3K of memory so it runs in most any Arduino MCU board, even the tiniest ones.
It uses cheap servo-motors and minimal components (but yes, some soldering is needed).
The most difficult part -- for me, anyway -- was the physical mounting for the motors and the drivetrains.
On my Maksutov, the motor is driving toothed timing-belt pulleys. The motor is screwed directly to the side of my Newtonian with a small wood pulley driving the larger focuser knob with a 3mm thick round urethame drive belt. My Lunt Solar 50mm uses a little homemade aluminum pulley with the same 3mm round urethane wrapped almost all the way around the helical focuser body -- the motor is fixed to the side with Velcro!
Of course, you'll need a personal computer that can run the Arduino IDE software (to program your electronics). And you'll need to be able to solder.
Full details -- including wiring diagram and the program -- are on my Wordpress blog: https://s4rc4sm.word...tor-controller/
There's a (very) short video demo, and also a link to github for the latest software. (I tweak, I can't help it)
What do you think?
  • markb and Andreas_Roerig like this
#2 cmooney91
cmooney91
  • Loc: Massachusetts
Posted 29 November 2021 - 10:43 AM
Very nice.
For others who are not as savvy with soldering and flashing, they could use a ready made "RC servo tester" with an extension cable to have a proportional control knob for the servo.
Edited by cmooney91, 29 November 2021 - 10:43 AM.
  • rlw1138 likes this
#3 rlw1138
rlw1138
  • Loc: 88W 42N
Posted 29 November 2021 - 03:12 PM
I wanted to do that -- to avoid having to do what I ended up doing! -- but I could only get it to work with a "normal" 0 to 180 servo. For some reason, none of my 'continuous' servos would turn. And I needed more than 180 degrees of travel.
#4 Josepm
Josepm
  • Loc: Lleida, Spain
Posted 30 November 2021 - 09:20 AM
Interesting... As I already have all the parts, I will try it.
As I wish to have the focuser control away from the scope, I assume that using a shielded cable to the rotary encoder will be fine.
Thanks for your post!
#5 rlw1138
rlw1138
  • Loc: 88W 42N
Posted 30 November 2021 - 11:04 AM
Shielding the control cable won't be necessary.
The "read_rotary_encoder()" subroutine I used should ignore any spurious 'blips' on the wires.
Pro-Tip: Mount the encoder and the Arduino in the same enclosure, and you'll be all set. If your enclosure is transparent (I used a plastic pill bottle) the red LEDs help you locate the control in the dark.
Also tagged with one or more of these keywords: DIY, Visual
