No nebulosity from Pleiades with Celestron RASA.
35 replies to this topic
#1 melodasi
melodasi
  • Loc: Nummela - Finland
Posted 29 November 2021 - 11:42 AM
I am struggling to capture some nebulosity from the Pleiades using my Rasa 8, ASI533 and a light pollution filter.
My last session I had about 700 lights of 60 seconds but I barely see any nebulosity after stacking and stretching.
Any advice?
Marcelo
#2 matt_astro_tx
matt_astro_tx
  • Loc: Dallas, Texas
Posted 29 November 2021 - 11:56 AM
Can you post the image?  With 11.6 hours of data from an F/2 system are you sure the image wasn't just totally clipped with saturation?  lol.gif
  • Jim Waters and Oort Cloud like this
#3 sbharrat
sbharrat
  • Loc: NJ, USA
Posted 29 November 2021 - 12:06 PM
Any advice?
Marcelo
Maybe the light pollution filter? bobzeq has his favorite RASA picture of M45 but I believe his is with just UV/IR and with 10s exposures.
  • Aquawind likes this
#4 Jim Waters
Jim Waters
  • Loc: Phoenix, AZ USA
Posted 29 November 2021 - 12:14 PM
Need more info.  How much light pollution?  What type of filter?  Where was the histogram on your images?  What were you using for image acquisition and processing?
Bortle 8 site without a light pollution filter.
https://flic.kr/p/2k9R6M7
Post an image...
  • psandelle and Oort Cloud like this
#5 gcardona
gcardona
Posted 29 November 2021 - 12:16 PM
I've used an IDAS LPS-V4 with good effect on the Pleiades from my bortle 9 back yard and my Hyperstar (F/2). The LPS-V4 has a similar response to the Optlong L-enhace. You need to make sure your filter passes the blue-ish band between 460-600nm or so.
#6 bobzeq25
bobzeq25
Posted 29 November 2021 - 12:17 PM
Well, the light pollution filter certainly hurts significantly, not helps.   You're correct that I didn't use one, on a reflection nebula (broadband source) they make no sense.  These so-called "light pollution" filters don't magically filter out light pollution, they just whack out chunks of the spectrum.  That doesn't work well on broadband targets, it does on narrowband sources, mostly emission nebulae.  I often use one for those.
But, _no_ nebulae seen?  That too does not make any sense.  60 second exposures are very long for a RASA.  My M45 (below) was 665X10 (ten) seconds (Bortle 7).
My recommendations to the OP, both are important.  Give us more information about the setup.  Exactly what filter?  Upload the unstretched stack (not the subs) to something like Dropbox, and let people here look at it.  It's hard to say what's wrong without the data.  I suspect it's something pretty major.
Edited by bobzeq25, 29 November 2021 - 12:26 PM.
  • rekokich, Skysmacker, Oort Cloud and 1 other like this
#7 melodasi
melodasi
Posted 29 November 2021 - 01:31 PM
Thanks guys for all the response.
Here is the quick stretched file.
The filter I used was the Orion  SkyGlow Ultrablock.
Here is the stacked file.
https://drive.google...iew?usp=sharing
Edited by melodasi, 29 November 2021 - 01:33 PM.
#8 melodasi
melodasi
Posted 29 November 2021 - 01:35 PM
Maybe ;)
#9 melodasi
melodasi
Posted 29 November 2021 - 01:38 PM
Post an image...
I live in a Bortle 5 zone, so I guess not a lot of light pollution, Image acquisition SGPro and processing with Photoshop.
Yep great picture in the link :)
Edited by melodasi, 29 November 2021 - 01:39 PM.
#10 pedxing
pedxing
  • Loc: SE Alaska
Posted 29 November 2021 - 01:39 PM
I think that filter is designed for visual, not AP - you're getting some crazy reflections from it.
I would remove the filter and deal with the LP some other way.
  • GoldSpider likes this
#11 melodasi
melodasi
Posted 29 November 2021 - 01:43 PM
Yeah, I am just looking at some marketing paper about the filter and it doesn´t mention astrophotography.
  • bobzeq25 likes this
#12 Aquawind
Aquawind
Posted 29 November 2021 - 01:52 PM
As a rookie I have had a couple of sessions with useless results. Now I always watch the images and even stretch sometimes to make sure my data is usable. It also let's me scrutinize and delete some files to avoid corruption. It really saves time in the long run. I am fortunate that I can do it remotely. I had good luck last weekend with the ZWO UV/IR cut filter only. My second night using the filter and first reflective nebulae. Next time it will be without the filter. Constant experimentation.
  • melodasi likes this
#13 HubSky
HubSky
  • Loc: Virginia
Posted 29 November 2021 - 01:57 PM
Looking at the transmission graph for the Orion Ultrablock, it is primarily an Oiii filter with about a 30-50nM bandpass (hard to tell) and the description for it says "increases contrast of emission and planetary nebulas".  So it will not work well with a reflection nebula such as M45.
#14 bobzeq25
bobzeq25
Posted 29 November 2021 - 02:14 PM
Thanks for the stack, cleared up questions I had.
Really bad filter for this.
You desperately need flats, and bias, necessary for flats to work well.  Math.
When you shoot without a filter, you'll need very short exposure to somewhat reduce blowing out the bright stars.
The principal tool to use to reduce the effects of light pollution (especially on broadband targets) is gradient reduction in processing.  Astro Pixel Processor has an excellent tool.  I highly recommend it.
Duo or triband filters work well on emission nebulae.  Only.  The Celestron LP filter for the RASA works some on emission nebulae, but is nowhere near as good as this.
https://astrohutech....t/idas-nbz-uhs/
Edited by bobzeq25, 29 November 2021 - 02:26 PM.
#15 jonnybravo0311
jonnybravo0311
  • Loc: NJ, US
Posted 29 November 2021 - 02:20 PM
First: lose the filter. It is absolutely killing your subs.
Second: take and use calibration frames (flats, darks, biases)
As Bob showed in his edit, there's definitely some nebulosity hiding in your data, but the filter is absolutely destroying it. Take it out... use it for anything OTHER than astrophotography going forward :)
  • unimatrix0 likes this
#16 17.5Dob
17.5Dob
  • Loc: Colorado,USA
Posted 29 November 2021 - 02:29 PM
That is a visual filter strictly to isolate the Oiii line. It's useless as an LP filter.
#17 melodasi
melodasi
Posted 29 November 2021 - 02:43 PM
Thanks. Yep luckily this filter came together with some user gear I bought in the past and I assumed wrongly how to use it.
#18 melodasi
melodasi
As Bob showed in his edit, there's definitely some nebulosity hiding in your data, but the filter is absolutely destroying it. Take it out... use it for anything OTHER than astrophotography going forward smile.gif
Hehe, yep you are right. Thanks.
#19 melodasi
melodasi
Posted 29 November 2021 - 02:56 PM
Thanks, I will definitely buy the proper filter.
#20 lakeorion
lakeorion
  • Loc: Lake Orion MI
Posted 29 November 2021 - 03:02 PM
There is nebulosity showing, but it's overwhelmed by the reflections.
#21 Fegato
Fegato
  • Loc: Llanfynydd, Carmarthen, Wales
Posted 30 November 2021 - 11:50 AM
In Bortle 5 you can probably dispense with anything other than a UV/IR filter. Shoot with no moon, and you should be able to pick up the nebulosity in no time at all.
Below is 37 minutes (74 x 30s) with RASA 11, but Bortle 3.  Some would say too bright, but it's what I went with, no work on reducing stars. And yes - flats, bias, darks.
get.jpg?insecure
  • 17.5Dob and bobzeq25 like this
#22 melodasi
melodasi
Posted 30 November 2021 - 01:26 PM
Great pi
Great picture. Yes, I am right now just waiting for the weather.
  • Fegato likes this
#23 bobzeq25
bobzeq25
Posted 30 November 2021 - 02:12 PM
get.jpg?insecure
Does the RASA 11 need a UV/IR block?  An advantage of the RASA 8 is an unusually apochromatic response, which focuses a wide range of wavelengths at the same point.  So, a UV/IR block will likely just reduce signal.
"Performs over a wider spectral range than most telescopes, from 400nm – 800nm, so more of the light passing through the astrograph is in sharp focus."
Outside 400-800nm is usually a low response region for CMOS sensors.
Bottom line.  I never use a UV/IR block.  I sometimes use a Baader neodymium to reduce light pollution.  Bortle 7.
#24 Fegato
Fegato
Posted 30 November 2021 - 03:27 PM
Ah, interesting question. Always learning in this game, so I've had a quick look at the RASA white paper. It does indeed say an IR cut filter "should not be required" for the RASA 8 (thus potentially allowing more detail to be caught). And it quotes 390nm - 800nm.  Not sure if this would affect colour balance, although maybe that's a minor point?
However, the RASA 11 range is 400nm - 700nm, so I think the IR cut is probably sensible. In any case, my ASI2400MC Pro has a UV/IR Cut window built in (although I guess it could be replaced with an AR one if there was any advantage to that).
#25 unimatrix0
unimatrix0
Posted 30 November 2021 - 04:04 PM
I have a couple of these filters myself.  While mine was actually saying astrophotography compatible, they are completely useless after testing them.
They could make a good DIY John Lennon style sunglasses though...
  • bobzeq25 and jonnybravo0311 like this
