Permanent stretch process/script
6 replies to this topic
#1 dchamb
dchamb
  • Loc: Brighton, IL, USA
Posted 30 November 2021 - 11:32 AM
In PixInsight, is there a process or script that can automatically permanently stretch an image? I know I can stretch an image by using STF and applying the instance to HistogramTransformation, and maybe I'm just a bit lazy but I'd like to see a process or script that combines these functions. I don't think it can be done in a Process Container.
#2 AbsolutelyNot
AbsolutelyNot
Posted 30 November 2021 - 12:05 PM
Soft Stretch in the EZ Processing Suite will do this.
eta the results are not exactly the same as STF/HT.
Edited by AbsolutelyNot, 30 November 2021 - 12:10 PM.
  • dswtan likes this
#3 kathyastro
kathyastro
  • Loc: Nova Scotia
Posted 30 November 2021 - 12:13 PM
I find the STF stretch to be too harsh for a final image.  I just manually adjust the sliders in the Histogram Stretch.  Sometimes I will use a Masked Stretch, which is a one-button process, though it typically does not stretch enough, and the image needs tweaking afterwards.
  • AbsolutelyNot likes this
#4 Jared
Jared
  • Loc: Piedmont, California, U.S.
Posted 30 November 2021 - 12:35 PM
The problem is that stretching is very much a “personal taste” process, so there is no script that will provide the best results for all images.
#5 gatsbyiv
gatsbyiv
  • Loc: Doylestown, PA
Posted 30 November 2021 - 08:50 PM
PixInsight actually has exactly the function you seek:  AutoHistogram.  Try these settings:
  • Enable Histogram clipping and leave the values at their defaults (0.010).
  • Change the stretch method to "Rational Interpolation (MTF)" and set the median value slider to 0.2.
That should pretty much give you what you are looking for.
  • dswtan likes this
#6 alpal
alpal
  • Loc: Melbourne Australia.
Posted 30 November 2021 - 10:29 PM
I use NASA FITS liberator to do the stretching:
https://esahubble.or...r/download_v30/
#7 dchamb
dchamb
Posted 30 November 2021 - 10:34 PM
Thank you! Looks like what I am looking for. I'll give it a try!
