Camera rotation displayed by Stellarium
Astrophotography
5 replies to this topic
#1 TAK346
TAK346
Posted 30 November 2021 - 04:13 PM
I select imaging targets using Stellarium for coordinates and camera rotation.  I have Stellarium installed on two computers - they give different camera rotation angles for the same target and orientation.  The angles are 60 degrees apart.  The known good computer/Stellarium gives 0 degrees and 90 degrees along the equatorial grid.  The other computer/Stellarium is 60 degrees off from the grid.  I have the same locations, sensors, dates and targets on each and can not figure out why there is a 60 degree difference.  Any suggestions on what I am missing?
#2 SkippyMcSkipperson
SkippyMcSkipperson
  • Loc: Troy, Illinois
Posted 30 November 2021 - 04:17 PM
Are they both set to mount type (equatorial or alt az) in the bottom toolbar?  Next to the "Center on Selected Object" button?
#3 TAK346
TAK346
Posted 30 November 2021 - 04:35 PM
On my known good computer the angle does not change when I toggle the equatorial or alt az setting.  The display changes but not the camera rotation angle.  On my known bad computer the angle does change!  I feel your suggestion is close to the problem but . . . why are the two acting different?  I feel that my problem is probably something very simple but it is driving me crazy.  Thank you.
Edited by TAK346, 30 November 2021 - 04:41 PM.
#4 SkippyMcSkipperson
SkippyMcSkipperson
Posted 30 November 2021 - 04:49 PM
How about the EQ mount checkbox for the telescope you configured, is that the same on both computers?
#5 TAK346
TAK346
Posted 30 November 2021 - 04:59 PM
You fixed my problem - and I would never have found it!  Thank you!  How is the St. Louis area?  I used to visit McDonnell Douglas then Boeing when I worked F-15 programs.
#6 SkippyMcSkipperson
SkippyMcSkipperson
Posted 02 December 2021 - 09:17 AM
It's OK, I try to stay out of the city, crime is getting worse in my opinion.
I live on the Illinois side, so if I can image any direction but west I can avoid that light dome.
Also tagged with one or more of these keywords: Astrophotography
