Animation sequence of 3 hours of Comet Leonard from Nov 29
3 replies to this topic
#1 ryanha
ryanha
Posted 03 December 2021 - 01:36 PM
I took my data from Nov 29 and made an animation sequence out of it.
Due to size restrictions on CN, I can only share via links to other services.
- YouTube Video: https://www.youtube....h?v=mnWHLghsZ_U
- AstroBin animated GIF: https://www.astrobin.com/lwmsmd/
Imaging details:
- WO 132FLT w/FLAT8 Reducer (F/5 @ 667mm FL)
- ASI294mm camera (L filter). 60s subs at 121 gain, bin1
- CEM 70 mount
--Ryan
  • JMP, Kenny V., h2ologg and 14 others like this
#2 astro rocketeer
astro rocketeer
  • Loc: Valencia, CA (Los Angeles)
Posted 03 December 2021 - 01:53 PM
Fantastic animation Ryan!! Did you dither when imaging? What program did you use to stack the frames? I had a hard time stabilizing my image when I stacked the frames and stars were just moving all over around.
#3 ryanha
ryanha
Posted 03 December 2021 - 01:58 PM
Thank you!
Yes I did dither, I think every 15 min or so.
Then I just used WBPP to flat subtract and register the images.
From there I resampled the data since I did not think I needed high resolution. (I used PI Image container for this)
Then I normalized the images (I used Tycho, an asteroid tracking software, because I was not exactly sure how to accomplish this in PI but I bet someone can tell me it is easy in PI :) )
Next I applied a common Histogram Transform to each of the images and then PI's batch convert to make them all PNGs.
I usually use PIPP to make animations, but it was crashing everytime on this data, so I used an online tool (https://ezgif.com/)
--Ryan
  • astro rocketeer likes this
#4 astro rocketeer
astro rocketeer
Posted 03 December 2021 - 05:55 PM
Thanks Ryan! Very helpful. Congrats on an awesome capture and animation!
  • ryanha likes this
