Counterbalanced mounts and Payload Capacity
Astrophotography Beginner Equipment Mount
5 replies to this topic
#1 unbreakable goose
unbreakable goose
Posted 03 December 2021 - 09:32 PM
Hi all, I have a bit of a theory based question that I am just curious about.
If a mount is perfectly counterbalanced on all its axis, then there is no net torque on any of the mounts axis i.e I think any perfectly counterbalanced mount should have an effective payload of 0 kg.
So from this understanding, any mount should have no max payload capacity, provided it is perfectly balanced.
This however is not the case, as all mounts do have a payload capacity.
Where is the gap in my understanding of the physics/Operation of the mount?
Thanks for your time!
Clear skies!
#2 sellsea
sellsea
  • Loc: South Bend, Indiana
Posted 03 December 2021 - 09:44 PM
There is bending stress and flexure in the counterweight shaft.  A setup that requires heavy weights needs a larger diameter shaft so that the shaft does not flex elastically.  The bearings in the RA shaft have their limits for smooth operation without wearing.
  • unbreakable goose likes this
#3 junomike
junomike
  • Loc: Ontario
Posted 03 December 2021 - 09:52 PM
The work (motor) require to stop/start 10lbs at each end (20lbs total) is a lot less then what's required to start stop 30lbs at each end (60lbs total).
Inertia and momentum can be  motor killers if over-worked.
  • unbreakable goose and Mark Lovik like this
#4 mrlovt
mrlovt
  • Loc: Smyrna, TN
#5 unbreakable goose
unbreakable goose
Posted 03 December 2021 - 10:17 PM
I didn't think about the mechanical stress on the mount itself
Thanks for the response!
#6 unbreakable goose
unbreakable goose
Posted 03 December 2021 - 10:19 PM
I suspected it was related to the intertia, but wasnt 100% sure
Thank you!
Also tagged with one or more of these keywords: Astrophotography, Beginner, Equipment, Mount
