Observation of the close satellite Dubhe (0.82 ") α UMa A + B
9 replies to this topic
#1 Konstantin 1980
Konstantin 1980
Posted 05 December 2021 - 06:46 AM
This morning the clouds are gone (Tambov, Russia), closer to morning the atmosphere has become quite calm. I decided to observe both visually and photographically close binaries. I watched and filmed a lot.
One of the results was a successful photo of the star Dubhe and its companion. According to the data to date, the separation is today about 0.82 ", with a brightness difference of magnitude 3. The satellite is visible visually at 254 mm at a magnification of about 500 times, moments, however, due to the not sufficiently calm picture of diffraction rings, one has to wait . But be that as it may, the result is excellent. As a result, the satellite is clearly visible as a disk at 2 o'clock in the photo., which I actually represent. I shot on a telescope with a Dobson mount! automated equatorial platform (homemade)05_57_55_дубхе b.jpg
  • Daniel Mounsey, payner, Astrojensen and 19 others like this
#2 Konstantin 1980
Konstantin 1980
Posted 05 December 2021 - 11:36 AM
  • Daniel Mounsey, inZet, BillShort and 6 others like this
#3 Bigzmey
Bigzmey
  • Loc: San Diego
Posted 07 December 2021 - 09:28 PM
Great capture Konstantin!
#4 Astrojensen
Astrojensen
  • Loc: Bornholm, Denmark
Posted 08 December 2021 - 12:09 PM
Extremely impressive! Both visually and photographically.
I tried spotting the companion last year in my 6" f/8 ED at 510x, but without success, despite very good seeing.
Clear skies!
Thomas, Denmark
  • flt158 and Rich5567 like this
#5 Cotts
Cotts
    Just Wondering
  • Loc: Madoc, Ontario
Posted 23 December 2021 - 06:52 PM
Well done.  I will certainly try this one visually with my new 20" Dob (when it finally arrives....)
Dave
  • flt158 likes this
#6 Cotts
Cotts
    Just Wondering
Posted 24 December 2021 - 09:27 AM
One of the results was a successful photo of the star Dubhe and its companion. According to the data to date, the separation is today about 0.82 ", with a brightness difference of magnitude 3. The satellite is visible visually at 254 mm at a magnification of about 500 times, moments, however, due to the not sufficiently calm picture of diffraction rings, one has to wait . But be that as it may, the result is excellent. As a result, the satellite is clearly visible as a disk at 2 o'clock in the photo., which I actually represent. I shot on a telescope with a Dobson mount! automated equatorial platform (homemade)attachicon.gif05_57_55_дубхе b.jpg
May I ask what the photograph parameters were?  Type of camera and its pixel size, focal length, ISO...  also is this a stack of many frames from a video or a single frame.  What frame exposure did you use?
Thanks.  I hope one day to take pictures of close binaries as good as this one.
Dave
#7 R Botero
R Botero
  • Loc: Kent, England
Posted 25 December 2021 - 03:04 AM
Roberto
#8 Konstantin 1980
Konstantin 1980
Posted 29 December 2021 - 03:47 PM
Dave
I got this image in the following way. I used a 254mm telescope (Newton) on a Dobson mount (on the equatorial Dobson platform). Astro camera Datison t7, the video contained 5 thousand frames, I used 1 thousand. I also used two Barlow lenses, 3 x and 2 x (at the same time)
the satellite cannot be identified in single frames, it is visible only after adding the frames
Edited by Konstantin 1980, 29 December 2021 - 03:49 PM.
  • Rich5567 likes this
#9 Cotts
Cotts
    Just Wondering
Posted 29 December 2021 - 04:13 PM
That's a very long focal length.  Assuming your telescope is f/6 then the two barlows combine to make the focal length f/36!  9 144mm
Your image scale is very close to 0.01" per pixel....
I will have to try using a longer focal ratio with my Mewlon 210 f/11.5 (approx. 2400mm).
Dave
#10 Konstantin 1980
Konstantin 1980
Posted 29 December 2021 - 04:40 PM
Dave
I am using a telescope with a focal length of 1200  ( Sky-Watcher Dob 10" (250/1200))   , it is difficult to say how much the final focal length will be, since there is a distance between the barlow lenses. But I can measure an Airy disk
