1994 AP Traveler, and 2024 AP 110GTX (Traveler II?). The mount is one of the original AP900s; 900HDA #4, from 1995. This is the 110GTX's first time out of the house since I got it in November (clouds)
For those that might be interested, this is a better comparison of how the size compares between the two, since they are both on the same focal plane. It is surprising to me how much more challenging and imposing it is to handle the 110GTX than the Traveler. The Traveler is 105mm, f/4.6, 488mm with the 92/105 TCC, with an illuminated image circle of about 40mm (based on the image circle specified for the Stowaway; I haven't found the information for the Traveler with the 92/105 TCC). The 110GTX is 110mm, f/5, 550mm with the 110 TCC, with an illuminated image circle of 50mm. Theoretically, if my calculations are correct, if you crop an image from the Traveler to the same FOV as the 110GTX, you would end up with a 38mm image circle, albeit with a loss off resolution of 11%. It will be interesting to see what results I get if/when I get a chance to do that (I would need two full-frame cameras to tell). I found it interesting how much further the focuser drawtube was extended on the 110GTX, and then I realized that the 110GTX TCC was inserted into the drawtube, and that was not the case with the Traveler.
The center of the 110GTX is almost exactly 1/2" further from the bottom of the dovetail bar, so I added two pieces of 1/4" aluminum bar stock under the saddle for the Traveler, but I am still working out the horizontal spacing. The fronts of the two 8" saddles are currently 0.2mm closer than the backs of the saddles, which is close but too much difference, and needs to be adjusted to be less. I am hoping to be able to image with both and combine subs into one resulting image.
Paul
