Mono Camera for Lunt 40mm
No replies to this topic
#1 Niklasgunner
Niklasgunner
Posted 06 December 2021 - 04:17 AM
I intend to get into solar observing and imaging and have decided on a Lunt 40mm, as well as a solarquest mount.
I am a lot less sure about the camera.
I was initially considering the asi 178mm because it seemed ideal for full disk shots. But reading about the grid pattern issues, which appear to be inherent to the sensor, I am not sure what else to look for.
Now I am looking at the asi 174 due to it seemingly being the most well regarded for solar h-alpha imaging, but it would undersample with a 400mm focal length. I would pobably need a barlow.
Would seeing become a concern when imaging with a 174mm and a 1.5x, 2x or 3x barlow? (this would be my first time using a dedicated astro camera, forgive me if this question sounds dumb)
Are there any other options I could consider that are less expensive than the asi 174 mm (120mm, 290mm)? I am not dead-set on full disk images, I could compromise on something that can't capture a full disk if it is likely to be issue free from NR and bayer matrix
Alternatively, how difficult is it to mitigate the issues that can appear on the 178mm?
Edited by Niklasgunner, 06 December 2021 - 04:57 AM.
