PlateSolve Sync with Celestron 6 SE using CPWI
2 replies to this topic
#1 roelb
roelb
  • Loc: Belgium, Antwerp
Posted 07 December 2021 - 07:23 PM
Hello,
I'm using a Celestron 6 SE mount with StarSense.
Use CPWI to do alignment (works perfect).
To do EAA I use SharpCap.
When, after successful plate solving, the command to align & sync is sent to the mount via CPWI,
the error "could not communicate with CPWI" is returned.
Note: when I use a plate solver outside SharpCap (Tortilla) the same error shows up.
Is their someone using this setup with the same experience? Or perhaps without this error?
Note: when I use the classic ASCOM Celestron Telescope Driver, no error is generated.
Thanks in advance replying.
Edited by roelb, 07 December 2021 - 07:25 PM.
#2 Cey42
Cey42
  • Loc: Kirkland, WA
Posted 07 December 2021 - 10:46 PM
I have something close to your setup. I have a Celestron AVX mount that I control using CPWI. In SharpCap under Settings/Hardware/Mount I have selected CPWI. I have never seen the error you have.
A couple of questions
  • Can you slew the scope manually from SharpCap? Or do you get the same error?
  • What version of SharpCap are you running?
  • Did this work before and then break? Or has it never worked?
#3 roelb
roelb
Posted 08 December 2021 - 01:01 PM
Slewing from within SC is possible.
Always latest version installed.
Sometimes it works, most of the time not.
I did contacted Robin Glover and we looked at this issue together.
Sent CPWI-ASCOM log files.
I think it is not SharpCap related because my "non-SC" test with AstroTortilla also generated the sync error.
I suspect the cause must rely in the CPWI driver talking to the SE mount.
I did also contacted Celestron but not received a reply yet.
