StarTools hangs on WIPE - anyone else have this problem?
11 replies to this topic
#1 kevinbreen
kevinbreen
  • Loc: Wexford, Ireland
Posted 09 December 2021 - 08:15 AM
Target: Orion at 250mm.
Versions 18.5.15 alpha and 17.458 both hang on initiating WIPE. The former flashes green once and the latter flashes green a few times.
Then I restacked at a different % in DSS. Still hangs.
Then I cropped to 50% instead of 71%. Still hangs.
Then I re-StarTooled a stack I did of a different target two days ago. Everything works fine.
Then I went back to Orion @ 250mm and didn't adjust "Ignore Fine Detail" in the AUTODEV module. Now it works fine.
Ignore Fine Detail causes StarTools to hang.
#2 Topographic
Topographic
  • Loc: Tarn et Garonne, France
Posted 09 December 2021 - 08:49 AM
If you are using the latest version there could be an issue with virtual memory, mine was low and increasing it made the programme run smooth and faster.
see https://forum.starto...memory&start=10
or
ask Ivo Jager on the StarTools forum, he is very responsive for advice and dealing with problems.
#3 happylimpet
happylimpet
  • Loc: Southampton, UK
Posted 09 December 2021 - 09:34 AM
Sounds like a personal hygiene issue.
#4 kevinbreen
kevinbreen
Posted 09 December 2021 - 09:51 AM
#5 F.Meiresonne
F.Meiresonne
  • Loc: Eeklo,Belgium
Posted 09 December 2021 - 12:14 PM
Never had that, not in wipe . But ignore fine detail is in the stretching, no?
I use 1.7.461, otherwise if you wish ,you could  load up your stack, so i can see if it happens on my machine too.
I am running it under win 10, 20H2 i believe , 32 gb of SDRAM , AMD Ryzen 5 3600 on a B450M board...
The only thing what sometimes happens is it hangs in the compose module, loading  a stack in the channel, might cause ST to hang.
Hope when the new 1.8.x version becomes stable, it is no longer the case.
#6 Topographic
Topographic
Posted 09 December 2021 - 01:20 PM
The only time I have had Compose hang is when I have tried to load data before the last data load is complete...impatient as ever smile.gif
#7 F.Meiresonne
F.Meiresonne
Posted 13 December 2021 - 02:03 PM
Had it again today....and i was not trying to load allready the next file...strange...
#8 Mikehuerto
Mikehuerto
  • Loc: Valencia, Spain
Posted 13 December 2021 - 04:15 PM
Hi, Im using Startools 1.8.506 alpha,  I have never seen it hang or crash. Used it first on a MacBook Air with an I7 processor and 8 RAM, then switched it over to Lenovo with I7 and 16 RAM. So Im wondering whether its your PCs processor speed or RAM?
#9 Borodog
Borodog
Posted 13 December 2021 - 04:27 PM
I got lots of crashes. It's one of the reasons I haven't shelled out for the software even though I thought the wipe functionality was pretty good. FWIW I have a quad core i7 with 32GB of RAM.
#10 F.Meiresonne
F.Meiresonne
Posted 13 December 2021 - 05:01 PM
Don't think so...i am using v 1.7.461, on a Ryzen 5 3600, 32 gb sdram. It does not really crash , it becomes partly unresponsive, i just can close it...start over and i might work. No real issue actually, just weird.
Maybe i should try the 1.8 version but it is still an alpha version .
#11 StarBurger
StarBurger
  • Loc: North Country NY
Posted 13 December 2021 - 05:26 PM
Happens to me with V 1.7.456. The wipe module begins to flash alarmingly but it always makes it.
I was told of a value in the registry that could be increased (something to do with the graphics). I did increase it but to no effect.
I just live with it.
#12 Sonya6500
Sonya6500
  • Loc: Bluffton , South Carolina
Posted 14 December 2021 - 11:33 AM
Are you processing a drizzled image? If so that is a huge load on the system.
