8.75" f/13 doublet, I kid you not
70 replies to this topic
#51 jragsdale
jragsdale
  • Loc: Idaho
Posted 20 December 2021 - 11:49 AM
Could I do DPAC with this thing? Just need to get ahold of a 10" flat, put this thing on some sawhorses and I'd be all set.
You can do an oil flat as well with a pan full of oil and the lens pointing straight down onto it.
  • Augustus likes this
#52 Augustus
Augustus
    Vendor
  • Loc: Tucson, Arizona
I'd need a 10 foot ladder to look down into it!
  • Kasmos likes this
#53 William Whitaker
William Whitaker
  • Loc: NE Tennessee
Posted 20 December 2021 - 12:43 PM
Would somebody please enlighten me about what DPAC is? Else direct me to a resource to help explain it and to not distract from this thread.
Inquiring minds and all that...
TIA~
#54 Garyth64
Garyth64
  • Loc: SE Michigan
Posted 20 December 2021 - 02:30 PM
I just googled it, lots of information out there.
#55 ccwemyss
ccwemyss
  • Loc: Massachusetts
Posted 20 December 2021 - 02:32 PM
It's amazing how quickly recent topics roll way down the list here and seemingly disappear.
https://www.cloudyni...c#entry11568821
Chip W.
#56 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 20 December 2021 - 02:44 PM
If you don't have a flat you can do what I do and test using a HQ scope and artificial star to produce a star at infinity.  Here's an article I wrote a long time ago about this.  Today I have several focuser insertable artificial stars I use to routinely test scopes indoors...
https://www.cloudyni...null-test-r1586
  • deSitter, Dave Trott, Gil V and 1 other like this
#57 Darren Drake
Darren Drake
  • Loc: Chicagoland
Posted 20 December 2021 - 02:47 PM
Here are 2 recently taken pics that show us testing 2 newly acquired scopes for the first time before they even saw starlight.
  • Terra Nova, rcwolpert, Bomber Bob and 2 others like this
#58 DAVIDG
DAVIDG
  • Loc: Hockessin, De
Posted 20 December 2021 - 03:00 PM
 Yes I highly recommend double pass autocollimatiion and test in the green.  Just because it is an Unitron doesn't guarantee that the lens is well figured. There are a number of Unitron  lenses that have tested excellent and some that have not been so good.
 You don't want to spend time and money to only be disappointed in the image quality. If the lens tests well and the image quality is not what you expect then you know to look elsewhere.
                          Happy Holidays,
                              - Dave
  • tim53, photiost, steve t and 5 others like this
#59 Augustus
Augustus
    Vendor
Posted 20 December 2021 - 03:09 PM
                          Happy Holidays,
                              - Dave
I just realized that my next Dob projects are using 5.5" secondary mirrors which would be a hair under 8" on the major axis. Would using one of these work for a DPAC flat?
#60 William Whitaker
William Whitaker
  • Loc: NE Tennessee
Posted 20 December 2021 - 03:11 PM
                          Happy Holidays,
                              - Dave
Oh, OK. Double-Pass Autocollimation.
That's the answer I was looking for. Thank you.
Edited by William Whitaker, 20 December 2021 - 03:16 PM.
#61 DAVIDG
DAVIDG
Posted 20 December 2021 - 03:41 PM
 Yes that would work to give a  you at a look at a good  part of the surface. A majority of optical errors are figures of revolution so if you test across a diameter you would see those errors. I would just be sure to test the area were the chip is to see if there is any problems in that area.
                     Happy Holidays !
                       - Dave
  • mdowns, rcwolpert, Bomber Bob and 1 other like this
#62 norvegicus
norvegicus
  • Loc: en route
Posted 22 December 2021 - 06:26 PM
So cool.  Congratulations.  I hope you're still looking through it when you're old and gray.
#63 Kiwi Paul
Kiwi Paul
  • Loc: Carterton, New Zealand
Posted 03 January 2022 - 02:09 AM
Hi Augustus,
This has been an interesting read. Up until recently I had an 8” f/12 D&G optical tube assembly which was mounted on a GEM built by a fellow by the name of Rick Stager. I saw it advertised in a Sky & Telescope mag back in the early 90’s. It was quite a job to set it up on the GEM even though the mount on a tall 4 inch steel tube pier was was mounted on wheels. Initially to get a look through it I built an AltAz mount which now that I think of it was like a Fobsonian. I built cage that enclosed the tube with about an 18mm plywood. It used hinges so that the telescope could be taken out of the cradle. On each side of the cradle I used a couple of large 4 inch heavy plastic(?) pipe fittings (don’t know what to call them) where they screwed to the wooden cradle and cylindrical part protruded about 3 inches. Then I built a base that sat level on top of the pier with a large circular surface of melamine or such which rode on pieces of Teflon. Off that base I mounted a couple of pieces of ply wound with cutout lined with Teflon into which the cradle around the telescope fitted for the Alt axis. This is essentially a Dobsonian mount I just (I could post some pics of you like). Anyway, I found I could get the scope up there and was able to look through it. The images were fantastic. The definition was sub peen and to the eye the achromat didn’t really produce too much false colour. I hope yours will be ok too. Anyway, later on I did get it mounted on its gem. To cut a long story short, I found that the long tube and associated heavy counterweights lead to a fair bit of flexure or ease of movement of the fov if one touched the telescope. It was a good thing both axes were motorised. I will follow this with a photo of the scope pointed at Jupiter last year.
Cheers Paul
  • Paul Hyndman, Bomber Bob and Augustus like this
#64 Kiwi Paul
Kiwi Paul
Posted 03 January 2022 - 02:21 AM
I tried posting an image of the telescope but don’t know where it went! It’s not easy on a cell phone!
Paul
#65 dave brock
dave brock
  • Loc: Hamilton, New Zealand
Posted 03 January 2022 - 05:44 PM
I'm late to this thread.
Have there been some deleted posts or part thereof? I see no statement that this is a Unitron lens, just a picture with a
Unitron focuser.
#66 Kokatha man
Kokatha man
Posted 03 January 2022 - 07:01 PM
...there were posts deleted as well as part of the thread's title Dave - mods felt that as the provenance wasn't authenticated it wasn't proper to retain that name in the title, nor in some of our replies like my own.....but for my money I'm a believer! (I am an optimist generally - although the admonition as to whether it is a good'un optically  like the one that fella in the Netherlands has - albeit with none of that ones bells & whistles that has - is still valid commentary!
#67 dave brock
dave brock
Posted 03 January 2022 - 10:28 PM
Thanks Darryl.
It's certainly an impressive beast in post #6. Kind of looks Unitronish. Pity the mount is no longer.
#68 Leia
Leia
  • Loc: SE Alaska
Posted 13 January 2022 - 05:32 PM
I've only read page 1, but this is one insane big fract
#69 deSitter
deSitter
    Still in Old School
Posted 13 January 2022 - 09:14 PM
Yes this might be a good role for a Questar or ETX! :) I don't have a Questar, but... I could never understand what that N-3C gunsight collimator was in Sam Brown - then one day, oh yeah! That works! :)
-drl
  • RichA and Augustus like this
#70 Augustus
Augustus
    Vendor
Posted 14 January 2022 - 11:22 AM
I am about to order a 6" minor axis secondary for my 22" project which I will use to DPAC the lens. While I certainly could use a good scope to produce an artificial star I'd rather just do this with a flat, since I'm getting one anyway.
  • Terra Nova and Bomber Bob like this
#71 norvegicus
norvegicus
  • Loc: en route
Posted 14 January 2022 - 11:43 AM
You'll need a ladder. Take pictures!
  • Terra Nova and Augustus like this
