Jaegers 6" f/15 Question
498 replies to this topic
#451 photoracer18
photoracer18
  • Loc: Martinsburg, WV
Posted 07 April 2022 - 07:26 PM
What I originally made as a pedestal mount for my AP900QMD was this:
I acquired the NOS Parks pedestal legs from off one of the forums a few years ago knowing they would come in handy some day. The thick aluminum 6061-T6 alloy tube came from a company that sells over the internet in standard lengths. I used an AP to Losmandy tripod adapter once I machined out the tube a little and drilled it for the bolts. I also found later that a SkyShed pier with a Meade SCT top plate is the correct center bolt hole for the center bolt to mount a Schaefer, at least my AT-9. Too short for your F15 scope unless you put a concrete pier underneath the steel one to raise it up.
  • Jeff B, mdowns, Bomber Bob and 2 others like this
#452 jragsdale
jragsdale
  • Loc: Idaho
Posted 07 April 2022 - 07:52 PM
That is definitely the worm housing of a Schaefer but looks like the worm , bearings, and shafts are missing.
I promise they're in there.
#453 jragsdale
jragsdale
  • Loc: Idaho
Posted 24 April 2022 - 10:50 AM
Sorry for the lack of updates. I was a little busy and then when I went for the final assembly, I found that the powder coating on the main 6" f/15 tube AGAIN had a large glaring mistake so had to be returned to the powder coaters for a THIRD time to be recoated. They've had it for going on 3 weeks now. The last recoat was a 24 hour turnaround, so I'm not sure what the hold up is. I think at this point they know repeat business is no longer an option, I'm considering leaving them a crummy review at this point, which is usually not my thing.
  • Bomber Bob likes this
#454 apfever
apfever
Posted 24 April 2022 - 11:07 AM
What kind of issues? I've never had a powdercoating done. I've considered it just to check it out on a larger restoration with plenty of same color parts. I can't do that much Candy Apple although I keep looking for the opportunity. It's still more of a highlight concept.
#455 jragsdale
jragsdale
  • Loc: Idaho
Posted 24 April 2022 - 01:00 PM
First time was a whole handprint in the finish. This time there's a 2" x 8" patch that looks like it dripped or wasn't coated all the way, it has a relief to it and is matte vs the rest of the coat. Very obvious in person and looks terrible.
#456 Jim Curry
Jim Curry
  • Loc: Eastern TN
Posted 28 April 2022 - 07:33 AM
I’ve had a fair amount of powder coating work done for a variety of reasons. It’s an electrostatic process not a wet process so they charge the metal positive or negative and then the powder is sprayed on and sticks and from there put in an oven to bake so either the tube wasn’t clean enough for the powder to stick despite the charge or there’s some other issue.
  • Terra Nova and Bomber Bob like this
#457 jragsdale
jragsdale
  • Loc: Idaho
Posted 03 May 2022 - 02:53 PM
Well, it took them 4 tries to get it right, but the powder coating finally came out excellent. They gave me a full refund plus a $25 Starbucks card so I'm ok with the inconvenience. Now I finally got a chance to get it all together and set it up for a test shot. Still have some work to do with the motors and drive corrector, but this should be good to go for the next clear night. It looks amazing in person, still deciding on placement for the Jaegers decal (I like it).
  • Joe Bergeron, davidmcgo, deSitter and 17 others like this
#458 Terra Nova
Terra Nova
Posted 03 May 2022 - 03:18 PM
That’s a great looking yard cannon! Good job!
  • jragsdale likes this
#459 norvegicus
norvegicus
  • Loc: en route
Posted 03 May 2022 - 03:40 PM
That looks pretty awesome.  If you get some instability it will be from your steel legs flexing and some struts should fix it...
#460 jgraham
jgraham
Posted 03 May 2022 - 06:33 PM
Wow, it looks amazing. Nicely done!
#461 Bob Myler
Bob Myler
  • Loc: Buford, GA
Posted 03 May 2022 - 06:57 PM
WOW.   Simply WOW.
#462 Defenderslideguitar
Defenderslideguitar
  • Loc: South West Connecticut
Posted 03 May 2022 - 07:55 PM
yes     looks beautiful        a proper job     worth all the time an effort
cheers
Edited by Defenderslideguitar, 03 May 2022 - 07:55 PM.
#463 CltFlyboy
CltFlyboy
  • Loc: Charlotte, NC
Posted 04 May 2022 - 09:40 AM
Top notch for sure. I saw your post on FB earlier today too - you did on heck of a great job. Love it!
#464 CHASLX200
CHASLX200
  • Loc: Tampa area Florida
Posted 04 May 2022 - 10:18 AM
That is what i need a older AP900 and a 16" high pier for a 10" F/6 Newt.
#465 CHASLX200
CHASLX200
Posted 04 May 2022 - 10:19 AM
Looks insane. Not working at my house but would love to have it.
#466 jragsdale
jragsdale
  • Loc: Idaho
Posted 04 May 2022 - 10:23 AM
It BARELY passes through the garage door. I have to put the RA to horizontal and the scope level and even then it has about 2 inches of clearance.
Here it is next to the Bolt, dwarfs it!
Edited by jragsdale, 04 May 2022 - 10:24 AM.
  • Marc-Andre, Terra Nova, Bomber Bob and 5 others like this
#467 jragsdale
jragsdale
  • Loc: Idaho
Posted 04 May 2022 - 10:25 AM
A proper first light. 👌
  • Joe Bergeron, jgraham, deSitter and 13 others like this
#468 Jeff B
Jeff B
    Anachronistic
Posted 04 May 2022 - 10:43 AM
#469 CHASLX200
CHASLX200
Posted 04 May 2022 - 10:46 AM
It's not fitting in my garage or house for roll out.
#470 jragsdale
jragsdale
  • Loc: Idaho
Posted 04 May 2022 - 10:50 AM
She said it looked cool. Haha!
The lens is sharp, no doubt, I still need to DPAC to assess the air gap size. CA seems well controlled but I'd like to know if it's under or overcorrected just as well. And I need to center the focuser and collimate the lens too for good measure.
  • tim53, Jeff B, Bomber Bob and 2 others like this
#471 deepwoods1
deepwoods1
  • Loc: Connecticut
Posted 05 May 2022 - 04:27 PM
WOW!!!! That really looks beautiful!!!
#472 deSitter
deSitter
    Still in Old School
Posted 05 May 2022 - 08:39 PM
Man that is crazy! :) It's big! Have a beer and start collimating :)
-drl
#473 jragsdale
jragsdale
  • Loc: Idaho
Posted 15 February 2024 - 08:48 PM
Wow, it's been a while since I've updated this thread. I haven't done any changes on the scope in a while, just casually enjoying it when time and conditions allow, so far it's been a really fun scope to have and use. I've been a little concerned with dew and stray light shielding (which is pretty important from my bright suburban driveway) so I set out to upgrade the dew shield.
The original stock dew shield was the 7" OD, 6" long Jaegers. It was just black anodized aluminum and did the job. But I wanted more. So I found this dew shield from an Explore Scientific AR152, it's 8" OD and 12" long with the included adapter. I had a 3D printed ring made to adapt the dew shield to the original Jaegera lens cell then drilled the appropriate holes to connect it all. I know this isn't the "original" look, but I needed a functionality upgrade and this provides it quite nicely.
  • tim53, clamchip, Josef1968 and 4 others like this
#474 RichA
RichA
  • Loc: Toronto, Canada
Posted 15 February 2024 - 09:18 PM
In the world of long achromats, it’s all relative!
The Yerkes refractor is 40” @ F19, (A. Clark and Sons); R = N/D = 0.475
The Lick refractor is 36” @ F19, (A.Clark and Sons); R = N/D = 0.528
The Lowell (Mars Hill) refractor is 24” @ F16 (A. Clark and Sons); R = N/D = 0.667
Jaegers 6” @ F15; R = N/D = 2.5
Generic 4” @ F15; R = N/D = 3.75
Generic 3” @ F15; R = N/D = 5.00
Generic 2.4” @ F15; R = N/D = 6.25
Generic 2” @ 15; R = N/D = 7.50
Where N is the F-ratio, D is the aperture diameter in inches, and R ~ 1/ chromatic aberation
Yerkes.  Same CA as 100mm f4 achromat.
#475 jragsdale
jragsdale
  • Loc: Idaho
Posted 15 February 2024 - 09:23 PM
I wonder if using just a green filter that blocks red and blue would give sharp and contrasty planetary views on Yerkes? Has anyone here viewed Jupiter or Mars through Yerkes?
