RASA 11 - problems with reflections/rainbows caused by bright stars
43 replies to this topic
#26 calypsob
calypsob
  • Loc: Virginia
Posted 21 October 2022 - 09:54 AM
I've recently ran into this issue as well.  I've had my Octopi attached to my RASA 11 v2 for about a year.  I run the rig with an ASI6200MC camera as well.
Not until about 2 weeks ago when I got serious about leveling the tilt of my camera via the Octopi did this 'rainbow glare' issue begin.  Before I got all four corners of the tilt adapter within 3-5 microns of each other was this 'effect' an issue.  My stars evened out with adjusting the tilt, but this glare effect started.  Ugh.  haha
I can get the flocking paper easily, but I'm concerned with cutting it accurately.  How did you guys cut it with precision?
PS. If anyone would care to sell me a 3D printed ring I'd be interested, but the one posted here is for an APS-C sensor and not a full frame, so I don't know if it'd even work.  I do not own a 3D printer.
It will take trial and error to get the size right.
I suggest a good circle cutter
https://www.amazon.c...,aps,111&sr=8-3
and some adhesive light blocking felt
https://www.amazon.c..._images_section
#27 Fegato
Fegato
  • Loc: Llanfynydd, Carmarthen, Wales
Posted 21 October 2022 - 09:57 AM
I'm still using my 5mm ring of flocking paper. To be honest it's not really a "precision" job!  I used a protractor to get the right width and just cut it out with scissors!  I don't use the Celestron filter, so I took the glass out of the filter holder and then screwed the filter holder in to hold the flocking paper nicely in place.
This has worked perfectly, so I never did get the printed part that Pablo created above. I'm not sure about your light path comment - you need about 5mm to stop any problems with a full frame sensor (in my experience - and I think same for Daniel above).  Is the printed part a different width? (I can't tell from the description).
In any case, you really need Flats with a full frame sensor, so hopefully they will sort out any other anomalies in the illumination of the sensor caused by this.
#28 calypsob
calypsob
  • Loc: Virginia
Posted 21 October 2022 - 10:50 AM
Sometimes I prefer flock honestly. It takes 20 minutes to measure and draw a part, then 4-9 hours to print not including failures, then you paint the part well and hope it has a good fit, prints shrink so there is always a degree of tolerance.
I always leave open the option of painting and using stick on flock, it can come in very thin mediums which is great in a area where you could end up creating an aperture stop. The hole cutter is also invaluable, we work with alot of round flat surfaces that can reflect light in this side of the hobby. Definitely take time to explore and choose the most efficient options for the job.
Edited by calypsob, 21 October 2022 - 10:51 AM.
  • jcrop likes this
#29 jcrop
jcrop
  • Loc: Texas!
Posted 21 October 2022 - 11:39 AM
Wes,
Right!  I wasn't looking forward to investing in a 3D printer and all the effort it takes to make the part, but kudos to those who do, honestly, they are talented.
Thanks for the links to a circle cutter and flocking paper.  I ordered the paper and cutter this morning.  I hope to be reflection free this Sunday if the weather stays as nice as it is down here in East Texas.  I'm surprised so many haven't had this issue.  I wonder if tilt is such a problem that it isn't an issue until the tilt is tuned up.  The reflections in mine didn't start until I tuned up the tilt, but that could be a coincidence.  I've had my RASA 2+ years and the Octopi for almost a year.  I tuned the Octopi up 2 weekends ago and then noticed the reflections.
Did you use only a single piece of flock paper?  Looking at the pics you posted in this thread it appears that way.  I want to make sure I'm not seeing that wrong.  Thank you so kindly and the others in this thread for showing me the way.  I appreciate it immensely.
Clears minds and clear skies.
-Jason
Edited by jcrop, 21 October 2022 - 11:58 AM.
#30 calypsob
calypsob
  • Loc: Virginia
Posted 21 October 2022 - 12:57 PM
Wes,
-Jason
I only needed 1 piece as you see in robins thread
  • jcrop likes this
#31 jcrop
jcrop
  • Loc: Texas!
Posted 21 October 2022 - 01:44 PM
Just to give you all an example of what I'm facing, here is a screenshot of the Witch Head IC 2118.
This wasn't an issue until after I tuned up my Octopi tilt adapter.
#32 calypsob
calypsob
  • Loc: Virginia
Posted 21 October 2022 - 02:30 PM
I suspect you are splitting rigel at the mirrors edge, thats a brutally bright star
  • jcrop likes this
#33 jcrop
jcrop
  • Loc: Texas!
Posted 21 October 2022 - 02:45 PM
This panel is part of a 4 panel mosaic and yes Rigel is not far away.  In that panel, believe it or not, Rigel doesn't cause as much reflection.  This is the worst panel as a whole since Rigel is just off sensor.  And what I've learned about this reflection problem is the star light on the *edges* of the sensor are the main culprits when imaging, not stars directly captured onto the sensor.
#34 Fegato
Fegato
Posted 21 October 2022 - 02:50 PM
Yes that is exactly what I was getting - rainbow arcs, just the same. Do as above, and they will disappear.
  • jcrop likes this
#35 Fegato
Fegato
Posted 16 March 2023 - 05:45 AM
I just got myself a square 50x50 UFC filter holder, as I thought this would reduce my vignetting a lot, caused by the 2" round filter. I have dark skies, so shoot mostly broadband. So I'm not too bothered that there isn't a 50x50 dual narrowband filter available, I'm happy to use separate Ha and OIII when I do go narrowband.
Anyway - turns out it makes no difference!  The little circle of flocking at the end of the lens group that fixes this reflection issue is causing a fair bit of vignetting itself. Oh well, back to the drawing board. I will try some progressively narrower rings to see how small I can make it (I'm getting some 3D printed). Anyone found a sweet spot any smaller than around 4-5mm, or does it have to be that small?
PS I finally got round to raising a ticket on this issue with Celestron, really for their info.
Edited by Fegato, 16 March 2023 - 06:05 AM.
#36 tom_halsingland
tom_halsingland
Posted 11 May 2023 - 04:28 AM
can it be reflections of the camera body? the ZWO asi-cameras reflect a lot of "rainbow" strikes, I guess. May be one shall try use a "sock" with some holes for the fan outlet over the camera body?
\Tom
#37 mayhem13
mayhem13
  • Loc: New Jersey
Posted 11 May 2023 - 05:37 AM
\Tom
I’ve always wondered about these glossy anodized and polished camera bodies with RASA and Hyperstar……and the heat plume coming from the fan right in the photon path…..but I suppose that can be mitigated with not capturing while the sensor is cooling.
#38 Fegato
Fegato
Posted 11 May 2023 - 07:45 AM
\Tom
I don't think so. As in the posts above, it's been fixed for us by blocking the outside few millimetres of the lens group glass. I don't think camera reflections would be fixed by this. Also, I would have thought any reflection from outside the front of the RASA would be much more diffuse?
#39 dlasserre
dlasserre
Posted 09 June 2023 - 01:10 AM
What the answer of Celestron ?
Thx.
#40 Fegato
Fegato
Posted 09 June 2023 - 01:12 AM
Thx.
No response I'm afraid. I haven't chased them.
#41 mosman1
mosman1
  • Loc: AZ
Posted 09 September 2023 - 04:13 PM
I also have RASA 11 v2 using with zwo large format camera, and have noticed one or two faint rainbows appear in stacked images, which are very hard to see in single subs.  I use Baader UFC so I have to remove the Celestron optical window for the UFC scope adapter to fit in correctly.
I notice that with UFC off and shining a dimmed flashlight into the RASA lens cell, multiple arc reflections of exact same shape as rainbows in the images appear.  No doubt these cause the problem.
I plan to try the 3D printed part since there is no good way to secure a 5mm floc ring in place without the Celestron optical window ring. Will likely get some vignetting but may be able to minimize that by using flats.
#42 sigxcpu
sigxcpu
Posted 02 November 2023 - 04:23 AM
Hi Robin,
It looks like the flocking material around the edge of the lens group does fix the issue - at least with my limited testing this evening. I decided to remove the flocking material and imaged a patch of the sky that exhibited rainbows, then re-added the flocking material and imaged the same exact patch of sky to see if the rainbows disappeared.
In the screenshot below, you can see on the left two faint rainbow artifacts on the single 60-second frame captured with no flocking material. Then on the right, the same exact framing and camera rotation, but this time with the flocking material. These are just single 60-second frames with an ABE in PixInsight. There are no rainbows visible!
I actually added a narrower circle of flocking material this time (~5.5mm), and that appears to be enough. I made sure it was black on both sides by sticking two bits of flocking material back to back, just in case the white backing paper causes any side effects due to its reflectivity. Obviously time will tell whether this definitely resolves the issue, or whether any other bright stars in different parts of the field of view still cause rainbows.
Have you had a chance to test something similar?
I didn't notice the rainbows in my images, but what I do see and it is the same in your images are the dark red rings. They happen with or without a filter.
Did anyone notice these and/or find a solution for them? There is a big one that touches the top and bottom edges and then concentric ones outside and inside less visible.
The train is Baader UFC, Baader tilter, Baader rings, RASA adapter, everything S70 up to M48 adapter to the ASI2600 camera. The filter holder is the first mounted thing on the camera.
LE: I've tried the 3D printed part, although I don't have rainbows, and it looks like it removed the red-brown rings. At least, I cannot see them anymore.
Edited by sigxcpu, 02 November 2023 - 07:59 AM.
#43 Kevin_A
Kevin_A
  • Loc: Belmont, Ontario Canada
Posted 03 November 2023 - 02:37 PM
I have only seen reflections that bad in camera spacers from being shiny black inside instead of flat black. I repainted all my 21 and 16.5mm spacers and my reflections went away. Not rasa specific related.
#44 Fegato
Fegato
Posted 03 November 2023 - 03:07 PM
Yes, that's why we all wasted so much time flocking everything we could in the image train!
However, this definitely comes from inside the RASA lens group. I did send a message to Celestron pointing this out, but perhaps unsurprisingly, got no response.
